Hi Guys,
I'm trying to restore the bloatware I deleted after rooting so I can update to the newest system version but I'm having troubles re-installing the NewsWidget.apk.
I've replaced the apk and odex files in the /system/app folder using Root Explorer but it just says "Application not installed" when I click the 'install' button. I've checked the list of default aps located here: (http://www.chadhaney.com/droidXDefault/) and I have everything on the list. Everything is installed other than the NewsWidget.
Any ideas on how I can fix this?
I rooted my phone using Sil3ntki113 RootMyX2 program if that has anything to do with it.
Thanks in advance!
Thanks in advance!
