BloodBlade
hi
i followed this tutorial tonight:
http://androidforums.com/galaxy-pre...od-rooting-prevail-dummies-written-dummy.html
it was very helpful. Thanks again Caeadas. i backed up my sd card to my computer before doing anything like it said and i partitioned the sd card. im confused tho what the easiest way is to restore my data from my folder on my computer that had the contents of my sd card? i didn't want to use mybackup from Google cause i saw there was a pro version and i didn't want to pay for it. the reason i didn't go for the free version was that there was a 30 day limit if i recall. anyway is there anyway i can restore my data from the sd card folder on my computer? or do i simply copy and paste the folders? if that's what i do how do i know which files and folders to copy? thanks in advance.
the post just wasn't clear... And I don't use winamp, so I just assumed... But now that you explained it, your correct... Its all good bro...
