Help Retraining Battery
inoh
Member
This is actually a 3 different subjects.
I just used odin to get DK28. All is great and I love this thing more than my old unlocked jailbroken 3G s. Now I understand that your are suppose to drain and recharge the battery 3 times to retrain it. Is there and app or syncing feed that will crush my battery extra quick?
What programs are good alternatives to tapatalk for talking on forums like this?
What are a couple of simple Battery status widgets or notifications that work well? The last two I used killed my battery, 1 was battery indicator and I don't remember the other.
Thanks in advance!
Run YouTube, that works for me. ;) You really only need to do it once and even then it's debatable. All you are doing is teaching the phone what the different battery levels are at (from my understanding).
Search for "phandroid" on the market. It's not the clock ;)
Thanks in advance!
Are you rooted or stock? Rooted, right?
Also, moved to support section. :)
Thanks in advance!
It's not a good idea to completely drain a lithium battery. You want to recharge it when it gets down to below 20%, to full, at least once a month. Battery doctor is a good app to use for battery management and reconditioning the battery.
Thanks in advance!
I think you answered your first question....download the battery status widgets you used before to kill your battery 3 times.
