Retrieving audio recordings.
Jdavid1
Once mounting my phone as a disk drive, how would I go about finding my recorded audio files on my phone? Also to listen to them would I need to convert them into some kind of new format to listen to them on media player? Thanks for any help.
I'm using the one that came with the phone. When I look for them through my computer though I cannot find them.
Try phone disk my documents then my recordings. Should be there. Should be able to listen to them.
If you have problems playing them on your computer, try a program called VLC Media Player. You can find it here http://www.videolan.org/vlc/ , like it says it plays just about everything without converting.
