mmoffitt9241
Member
I've got a rooted stock Froyo Captivate. I've been having the random shut down problem so I want to return it for Warranty. Before I do, I assume I should unroot...What's the best way? I saw on XDA that you can completely wipe it and go back to stock but then I loose my contacts and stuff...I used SuperOneClick1.7 to root and it has an option to unroot...so should I just use that?
Also, I deleted some of the ATT crap...will they notice? because it won't let me restore it from Titanium for some reason...
Are there any other files or anything I need to make sure I delete after (or before) unrooting?
Is there a step by step? I tried searching the forum but so much other stuff comes up that isn't what I need (other phones and subjects) that it was such a pain....
Thanks for your help!
Mike
Mike
