Factory reset.
I want to return my Nexus 10 that has been rooted and has twrp on it... How do I get it to condition it was when new purchased in Walmart?
Hi 4ubest. I moved your thread to the All Things Root forum. You need to use the Nexus 10 Toolkit to reinstall the stock rom. Option #9. That will unroot you and also install the stock recovery. Then use option #3 to relock the bootloader.
Thank you, I appreciate your help and knowledge.
You're welcome.
Why did you decide to return it?
If I do the power and volume up down I get a screen with the guy lying down and it says Downloading,, do not turn off target...
That's the bootloader screen. When you're in the bootloader screen, use the volume buttons to cycle through options and select recovery. You see it changing in the top left corner. Use the power button to select recovery. At the next screen where it says 'no command' I think, hold down the power button and push the right volume button once. That will take you to the stock recovery. From there do a factory reset. It should boot normally now.
