I see there are a couple of threads on this but I want to make sure I have this right. I just got off with Asurion and they are shipping a replacement. I had rooted my phone, installed some root only apps like wireless tethering and set cpu, removed some bloat like CityID and Tweet/Peep, and changed the boot animation. No custom ROM or radio update.
Then I wanted to get the OTA update so I applied s-off and flashed back to stock recovery.
So what do I need to do to return this phone. I know I will need to apply s-on. Then should I flash a stock 2.1 or just revert the changes I made to boot animation, restore the bloatware, and remove the root apps? Do I need to remove any other files that go with being root? Thanks.........MM
