Revert to old Firmware??
agentc4
Does anyone know if there is ANYWAY to revert back to the older firmware for the EVOso i can root? I already wiped my phone completely and that didnt do it. :confused:
Yes. There is an exe sitting over on the xdadevelopers forum (sorry, my link is at work). It will flash the phone back to the day one firmware version.
Remember, back your stuff up first.
Firmware or OTA update? Firmware is the android OS isn't it? I'd like to remove the last OTA update as it caused some problems with my phone.
Firmware has nothing to do with the software update, which I'm sure the OP is describing. I think 1.47 is rooted now though. So ultimately you could root, then flash a rom still on 1.32 I believe it was
From everything I've been reading today the 1.47 update can't be removed.
Let me see if I've got this right though. You can root 1.47 and then use a rom that is still based on 1.32 there by 'tricking' the phone into thinking it's running on 1.32 but is still really running on 1.47?
I'm new to rooting so I'm still trying to wrap my head around all the terms and stuff.
Have you tried rooting even with the latest OTA update? It is doable now. The XDA forum has the instructions.
Sent from my PC36100 using Tapatalk
no it would not be still running on 1.47, it would be running 1.32
roms are basically customized firmware. firmware is the android software installed. so when you root you gain access to the parts of the phone that developer's need to make the phone work. after you root (unlock), you will do a backup of the rooted firmware. this backup would be rooted 1.47. then you flash the rom (load the new firmware) and you are running THAT rom and not anything else. it's like when you update from windows xp to windows 7. once you load windows 7, there is no xp on your computer. you are replacing ONE version of firmware to another (in this case you are trading rooted stock rom w/1.47 for a rom w/1.32)
this is why people love root: you can get find roms that you like, you can remove crap that you don't like, you can make your phone do things you never thought it could, and if you are geeky you can probably create something really awesome.
