Bandage
Member
OtterBox Commuter Review
Just got my OtterBox today, so thought I'd toss out some thoughts for those of you on the fence.
Those of you that aren't familiar with the OtterBox cases check out some info here OtterBox Case Series
Fit: This thing fits so effin nicely! I've tried the Commuter series on a few devices...and this seems to fit more snug than on other phones. The 3D Commuter I had seemed to bunch up ever so slightly. Same with Dell Streak and Evo 4G versions. My Galaxy S phone was pretty snug as well. Seems like they got this one right...cut-out for the mic doesn't look like it'll get blocked over time if the rubber gets loose.
Button overlays: They stick out a bit...which is the norm for Otters. I find them to be pretty handy. The power button especially, as most would agree without a case it can be a bit of a pain to press. Nice that I can stop myself from filing a fingernail on the volume rocker too. Much easier to press than the few other cases I've tried as well.
Dust Flaps: Tight and secure...without being annoying. Easy to open...plenty of room to plug in your cables. Not too stiff. Seems like they'll hold up for awhile. I've had some others that have fallen off way too early in the case life. Noticed the flap over the HDMI / USB ports DOES make the phone wobble a bit when using kickstand. Not a big deal...but might be an issue for some.
Cut-Outs: My only complaint here is with the kickstand cut out...seems a bit too snug. Seems to get caught a tiny bit on the rubber around it as you try to extend the kickstand. Pretty sure it'll straigthen itself out over time tho. Camera cut-out is nuttin special...just a rectangle around the lens and flash. Has cut-outs for the noise cancelling mics on the back as well.
Appearance: LOVE how it doesn't take away from the MoPho's unique look. I've gotten compliments on my phone for how slick it looks with the cut off corners. Yea.it's the little things that count. This isn't a case that hides the look of your phone...it accents the goodness!
General Feel: Not too slick....not too grippy. Slides in and out of pockets just fine. Definitely doesn't feel like I'll drop it. Always a good thing in my book. EDIT 8/11 - Noticing a bit of plastic "Bite" on the sides and bottom. The plastic is hard and a bit sharp. Irritates a bit...perhaps with time it will dull on the seams / edges.
So...in conclusion: I think this is the case I'll stay with for awhile. I've always enjoyed the protection afforded by OtterBox cases...and this should be no different.
Be aware, unless you rip out the insert on the HDMI dock it won't fit. You will have to remove the case for dock use. It does fit just fine in the car dock however. Once rooted, the HDMI dock isn't as useful with the Web Hack available anyways...so no biggie.
