HaTrEd360
Android Expert
So. I'm back. And I want to try again for the 3rd time to fix my permanently bricked phone.
Recovery won't install roms. They just hang on installation, no matter what rom, and what recovery.
4ext reports that the rom installs in the info, but the problem is that it only installs a few things, and all the things in everything except system.
MY SYSTEM PARTITION IS COMPLETELY CORRUPTED.
So as it is, I need to know some commands to completely erase the partition and rebuild it. Something kind of like parted... I've seen it work on other phones I believe. (if I'm thinking parted is the same thing I need.)
Basically I have a lot of bad blocks. I've trying repairing it, and it doesn't fully repair it. It just won't repair some of the blocks.
RUU does NOT work. It did once and the phone worked for a few days then broke again. I think it just installed enough data to parts of the system that were good, and that was completely rare. Every time I install something it makes more blocks bad.
So I need to not format system as that does nothing. I need to delete the entire thing off the phone, and then recreate it after formatting the entire drive or something of the sort.
At this point I'll try anything. I just want the phone for the camera, and bigger screen then my current F3.
Last I remember it got completely corrupted by using PACROM. And it occurred when I noticed my brightness could be changed by sliding the status bar. Normal right? No. Because the setting was turned off in the settings... So I turned it on. It crashed the status bar. Kept force closing. Phone rebooted. Then it booted without a status bar, but no force closes. I turned off the setting then it rebooted, and wouldn't stop after that.
It doesn't soft reboot. It fully reboots, like a battery pull.
And sometimes it will randomly just fully reboot while I'm sitting in recovery, or in the bootloader. It doesn't happen often, but it has a few times.
With that being said!
can someone please do some research on how I can repair it? I have a Windows 8 Asus computer, and drivers are installed, as well as ADB. I'm S-off as well, on stock bootloader unlocked. (RUU flashed everything back to stock, just doesn't finish the system. It errors out on unzipping it, and says UZ-FAIL I believe.)
Thank you ahead of time.
Whoever can get this fixed will get a $5 donation.
can someone please do some research on how I can repair it? I have a Windows 8 Asus computer, and drivers are installed, as well as ADB. I'm S-off as well, on stock bootloader unlocked. (RUU flashed everything back to stock, just doesn't finish the system. It errors out on unzipping it, and says UZ-FAIL I believe.) Thank you ahead of time.
g'luck!
