Root revolutionary problems
GodofBore
the program wont stay running on my computer (windows 7) what am i doing wrong? It pops up and disappears upon running?
id suggest checking out the stickys at the top of the forum,lots of info there. :)
if you allow revolutionary to install clockwork,all you need to do if you want to be rooted is flash superuser in the clockwork recovery that the program installs.
from there the sky is the limit. you can flash roms,kernels,overvclock or undervolt, or just remove "lets golf" and some vzw bloat ;)
your cigar and blazer are on the table,post up if you have questions :)
