Hi,
Got my Rezound yesterday afternoon.. and it was working fine till earlier this morning when it started to forget where it is.. the time kept flipping from ET to CT to PT and then back to CT. Called Verizon Wireless. Battery pull didn't fix. Factory reset didn't fix it. They don't have an reported issues .. but then again it is a new phone. I've resolved the problem temporarily by telling the phone not to auto update based on location. But that doesn't seem like a good solution.
Anybody else experiencing this issue with the Rezound or other 4G/HTC phones?
Have you turned Location settings on? It gives you options to set GPS settings etc. Do you have a case on your phone? Are you using an SD card from another phone? Does the phone exhibit the symptoms immediately after activating the phone without restoring content on it from some other source?
