2011mazdaspeed
looking to trade my razr for a rezound, BUT one thing that is in back of my mind... what about that devices that dont support ad hoc... has this been fixed? anyone try FoxWi with rezound??
You can flash one of the ics roms and use wifi tether in infrastructure mode.
Are you rooted? Only works if you're rooted. On Wifi Tether, follow these instructions.I just tried Fox and WiFi tether does not work, as they state in their description. Tried Bluetooth but it didn't seem to work right either.
Set Device profile to Galaxy Nexus, change setup method to Netd Master. Make sure Wifi Driver reload is checked, enable access control (people won't be able to use the wifi) and finally, check routing fix to on.
Turn on Wifi-tether and you're good to go![]()
I tried these directions and I'm afraid it didnt work for me. It wouldnt even broadcast despite showing that tether was active. And to confirm, the profile was attempted with SamSung Galaxy Nexus LTE and the other profile for GSM.
Any other suggestions? Thanks for your info
Good to know it works, I use this for pretty much all my wi-fi devices and its very stabled and reliablei can confirm, those settings dont work with stock rom. dosnt broadcast - just simply flash cleanrom 4.1 (make sur eto do fw upgrade before tho!) and it comes wth wifi tether, and simply follow the directions above and it will work, im on WPA2 encryption and works veryyyy well. no problems.
