RGB & Alpha Colors for Blue Color on ICS??
eddieruko
Does anyone know the RGB & Alpha numbers that make up the blue color on ICS? I think I've gotten close, but if anyone knows for sure... that'd be sweet.
I've got Circle Battery Widget and trying to replication the colors used in the notification bar (time, signal, etc).
Thanks!
I was after this as well, so i took a screenshot, stuck it in photoshop, sampled the battery then converted the RGB into hex. The results: RGB: R: 57, G: 146, B: 181 Hex: 3992B5 (or FF3992B5 with alpha)
I was looking a while back and found this in a thread somewhere
Hex:33B5E5 (or FF33B5E5 w/ alpha)
R:51 G:181 B:229
