Help Ring Lock
BrandonOptimus
Is there a way to get the ring lockscreen from BobZHome to any CM7 rom? Or is it a specific build? I see many roms with a ring lockscreen so I was just wondering if it's something that comes with the rom like an apk, or zip that could be flashed over to a rom? I really do like BobZHome Reppard's and Playful's CM7, but i was just wondering why some don't have that feature in them.
Bobzhome Rom is the lastest version of CM7 That's why the mod works. If you wanna use ring lock without this rom you can try Widget Locker as it now features the ring lock from ice cream sandwich
Magiclocker and the android4 theme is what I use to get the ics lockscreen on my admire.
