Robinelli
To save a specific ring tone to one person, you can go into music player and select the ringtone (which was previously created in ring droid) and select add new contact. Put in the persons name and number. It will then link the "new"contact to the one already in your contact list. There should be an option to add to existing contact but it isn't showing yet so this is the only way I've found to set individual tones using ringdroid.
