Help Ringer volume keeps turning itself to maximum
JezterVA
Anybody else have the problem where the phones ringer volume keeps setting itself to maximum? This started two days ago when I used Lookout to locate my phone. I can turn it down, but it just keeps turning itself right back up. I can silence all sound from the settings menu and it just turns itself right back up? Was hoping to find an answer here before I go to the store for a replacement.
I've pulled the battery and performed a hard reset as well as uninstalled lookout. Don't know what else to do. Any help?
Problem hasn't happened for well over an hour now, so I may have fixed it. I cleared all the caches from my installed programs, removed any programs that I haven't used in over a month, pulled the battery and did another hard reset. So far, so good. Hopefully it will remain in this silent(er) state. :cool:
Now that I think about it, I deleted all my text messages as well. There was one in my inbox from short code 99999 and the text was "(ring)(giggle)".
Are there viruses and worm-like apparitions for this platform? I'm assuming there are, since look-out scans for viruses. Now I'm intrigued. Hmmmm.....
