Very strange issue... If I go into the sounds and display and select my ringer its loud enough that I put the overall ringtone volume at one notch before the max. The weirdness starts when someone actually calls me. When I get a phone call the ringer sounds like its about half volume, so after the call I go an check and its still one notch from max. Now even weirder is all the clicks and noises throughout android are even quieter. The only way to make them as loud as they should be again seems to be opening voice to text then everything is the volume it should be. I don't have quiet ringtone when picked up turned on, and all my volumes are adjusted right. Anyone have any clues as to what I can try to fix this?
