latinmaxima
Android Expert
I did some searching and haven't found a similar issue. I also don't know if this is related to using Ringdroid or Android 1.5 or my phone. Please let me know if you have run into this though. Also I have contact Ringdroid for any feedback as well.
I have created several ringtones, alarms and notification tones using ringdroid. It creates the sd>media>audio>ringtones, alarms and notifcations
It is fine if I turn the phone off however if I have mounted the sd card to access the sd card via my computer. I correctly safeley remove the connection and the sd card checks for errors and loads fine. My mp3 player is where I stopped. Pictures load fine.
However all of my tones assigned via my folder list above display as unknown and I get a wierd ringtone. It never recovers the tone unless I go back in and re assign.
Has anyone else experienced this issue? Whether using Ringdroid or simply creating the folder list and using it that way on the sd card or any other ringtone creator or custom tones.
