ringtone question
ebdozit
Member
Can you select any song from your library and use it as a ringtone?
Are you able to edit each contact so that their ringtone is a song from you library?
Yes, this is possible. Go into contacts and click on each one that you want to have a personal ringtone, and the option to assign the different ringtone will be available.
