bradleypariah
When you have headphones plugged in, the ringtone still outputs via the built-in speaker.
That seems wrong - if you have your headphones plugged in, you obviously are trying to keep sound private to yourself, but if you receive a call, audio in the headphones is cut off, and then the ringtone comes out the speakers... why? This is my 3rd Android phone, but it's the only one that did this. The other two sent the ringtone out the headphone jack whenever it was in use.
Does anyone on here know of a way to fix this ringtone output issue - whether it be with an app, a current internal option, or perhaps by rooting the phone?
I simply want to force the phone to use the 1/8" headphone jack for ringtones when the headphone jack is in use. Anyone?
Thank you very much in advance
