Ringtones also showing in media player
xiaoali
Ringtones I put in the ringtones folder are also showing up in the Samsung media player. Is there a way to avoid this?
create a file called .nomedia in the directory where the ringtones are and the media scanner wont scan that folder.
Peter
Get a File Manager (like Astro), mount the drives to your windows machine, or use the 'My Files' application to do the following:
Remember you have your internal SD card (the 16GB one that comes with the phone, it is located in the file system on the phone as \sdcard), and your external (removable) SD card that you provided (it is located in the file system on the phone as \sdcard\sd)
you need to create a folder on the internal SD card for your ringtones.
Create the following directory:
Code:
\sdcard\media\audio\ringtones
more than likely there will be a notifications folder in the same place, just create the new folder there. Move all your ringtones into that folder. Once the file(s) are moved, media scanner should run.
From there the ringtones will no longer show in the default media player (mine were also removed from cubed which is the player i use), but are still accessible when selecting 'Phone Ringtone' when assigning ringtones.
I use mixzing and it lets me determine the highest level of folder to search for music. I put all my music on my external sd card and have mixzing only search the external sd for media. All of my ringtones I put in my media file on the internal sdcard. Since it goes sdcard/sd, the "highest" mixzing will search is just sd. I believe Meridian media player will let you do this as well.
I did mine this way... much easier. Thank you!!
Check this out:
StudioKUMA .nomedia Manager - Android app on AppBrain
chart
I selected my 'media' folder from the internal sdcard, marked it as no media, went into the media player, *poof* my ringtone and notification (both from a Creep sample :) ) are no longer displaying :D
I haven't experimented any further, but it seems to do what we were all discussing. I tried to make a .nomedia file manually, but it didn't seem to work (or something about the file itself wasn't correct). This is _super_ simple.
don't you have to pay for mixzing ?
