while i don't use my nexus s to make many calls, i too, have noticed this
i got ringdroid to set up some ringtones, and this morning i got a call but it was on the default ring... i'm very perplexed, cant imagine spending all that time on customizing each person's ringtone just for them to reset...
There is a fix, although not a very smart one. The ring tones tend to be reset primarily once the device has been connected to the computer as usb device. For some reason after disconnect when you get preparing sd card the system
Mine does it all the time also. Usually lasts about a day then switches back to the defauls. I have not connected my phone to my pc inbetween so I'm not sure that is the issue. I have tried several third party apps thinking it was that, but it still switches back. Very frustrating as I use my phone as a pager and the default does not last long enough. Anyone find anything or hear of a fix?
I've had it start happening to me. Changed my email notification to a song. I had 6 emails in a row and had 6 different versions of the song playing out of sync.
