Ringtones dissappeared
Shofar
Sorry if this is considered a double post but I realized that my title was not helpful for me getting some help.
My ringtone seems to have reset itself to something I haven't choosen.
I have trouble hearing high pitch sounds so this is important.
I need a ringtone that I will notice.
I go to sound & display and when I hit "Phone Ringtone" the only options are OK or Cancel.
Same result using the "personalize" setting.
Where did my ringtones go????
Please help I do not want to reset to factory and loose the few settings I have.
I finally shut the phone off (not reset) and when I powered up again my ringtones were there.
I still don't know why they dissappeared???
Downloaded some Johnny Cash ringtones as an app. Can anyone tell me how to get them so I can use one for my ringtone?
Thanks
Thanks
You just open music as if you are going to play the song, press the menu button & theres an option there to set as ringtone.
There is an app on market place called tone picker, its free & it lets you use music files for ringtones & sms notifications.
