Ringtones for tex messages
I'm looking for the same answer...very frustrating. even called verizon tech support. they said to look in the manual but all the manual tells me is how to set a sound, won't tell me how to add a sound to list of choices.
Can u Change the ring tone for text messages to a song i can't ever hear the default one
Connect your phone to your PC and mount your SD card. Create a folder called notifications on your SD card and copy the song you want to that folder. You'll then be able to use that song as a text ringtone.
I just went into my text messaging, hit menu, and then went into preferences. You can set up a custom notification for texts there.
(This is the same for gmail and also for emails.)
FINALLY!!!!! Indeed ringdroid did what I have been searching for since I purchased the Droid!!! Yea!!! if only it could be differentiated with gmail and other notifications.....
