Root Ringtones no longer work.....
S
sexymandroid
Guest
Hey guys, my Triumph ringtones just suddenly stopped working. My audio is still working because music and other media still play, but my phone refuses to ring for calls and texts, etc.
I'm running CM9 10/25/12 build. Help would be appreciated!
There was a version I wiped to many ringtones from trying to get GoogleNow to work. I would recommend upgrading to the newest version 11/13/12
Would that also apply to custom ringtones though?
No not custom ring tones just the stock ones. I also removed all the old ring tones that where from gingerbread. It freed up another 20MB from the ROM. The only tones I have are CM tones, and ICS tones by default. If your custom ringtone is not working switch to another ring tone and test, and then try to add back your custom.
So for some odd reason my phone was stuck on the silent profile. I had to into the settings and then profile menu to change it. Everything's ok now! Thanks for your time g60! You da man!
Glad its working. If you hold down the power button for a few seconds it will also pull up the profiles.
