ringtones not working
badfrog
ok, I had this problem in 2.1v2,
I installed v3, and it first, all was well, then yesterday I noticed the same thing...
none of my custom set ring tones are being used. phone always rings with the system default.
I can change that, and it rings that tone, but any I assign to a contact don't work.
I haven't installed any ring tone managers or anything, I can't think of what would be messing with it, but it is friggin annoying!
anyone else have this problem or any insight?
ok, since I have nothing better to do this morning, I started trying to figure it out.
reboot phone... ringtones work, ok. thats a start
hit "end all" on my task manager, doesn't work. AHA!
ok, what starts at reboot that task manager is nuking that may control ringtones..
exclude "people" from end all.... problem seems to be solved.
