The past 2 days my ringtones keep going back to stock, I got these ringtones that I've been useing for a long time but now they won't stay, after a few min or hours it goes back to either stock or the ringtone after....
is it by chance after you unplug your phone from the computer that you mounted your sd card on? if your sd card is unmounted your ringtones will revert to stock. best advice i can giveyou is to convert your ringtones into .ogg format with audacity (google it) and put them in system/media/audio/ringtones/ this way your custom ringtones are now "stock"
That's problably it, cuz my media scanner kinda freezes up at times, so it probably don't read the directories fully. A little while ago l I just deleted the stock ringtones and notifications and I'm fixing move my ringtones to the stock folder once I get the audio converter
Thanks for the advice
