Root "Roaming Indicator On."
wer
Member
So i Flashed Dirty Unicorns V 1.1 and it has a r above my mobile data lines and when i pull down my notification bar it says roaming indicator on. whats going on?
They are off, theres no sprint only setting either. but it still says roaming in my notification bar pull down thingy.
Virgin doesn't have data roaming so even if it says it's roaming don't worry about it because you have nothing to lose (thanks to prepaid).
The tower also rejects your phone so it won't connect thus not allowing any data transfer.
