Help Roaming problem
porga
I wrota about this issue before, but now it happened on Galaxo too.
I am on Tele2 here in Croatia. Since they do not have infrastructure everywhere they use T-Mobile infrastructure. When I initiate network search (when everything was OK) i wold get three operators listed:
-Tele2
-T-Mobile
-Vipnet
I woud select automatic. Then, when I am in Tele2 antenas range signal icon was normal, and when I was in T-mobiles antenas range signal icon got little "R" on it (roaming). This is important beacuse data transfer is very expensive when in roaming.
From some reason, when i initiate network search now I get:
-Tele2
-TELE2
-Vipnet
so now TELE2 is T-mobile ( i get network info by dialing *107# - Tele2 on T-mobile network ) and roaming icon is lost. Why is this happening ???
Call your carrier. How do we know)
Here in the UK, Three network also uses other carriers' networks, where it has no signal. But this roaming is transparent to the end user - e.i. we don't pay any extra for using data or making calls when roaming. Are you sure you will be charged for roaming?
Yes, on roaming is super expensive. But my question is why Galaxy changed way it interprets roaming network.
I had this issue before and after reflashing was OK. So it is not network issue, but phone software issue.
Well, if you do know which network is actually T-Mobile, then you simply have to look out for the network name before using data. You could try re-flashing different firmware, if you htink it has something to do with it. I guess it may.
