I bought a cheap curtis klu tablet (lt7035-j) with no other intentions then to hack it. basically for me its not what it can to, its what I can do to it like a toy.
having said that I have flashed it numerous times finally leading to a soft brick and now have a few questions.
I can still flash it using rkbatch and rkandroidtool. rockusb mode and or mask mode i can always seem to get into and reflash whatever i want as long as the flash is related to that chip. now it wont boot any screen on the tablet. heres a few thoughts i have had and would like to know from the experts if I am correct and some thoughts related.
question and quesses......
the files flashed with rkbatch, what some of them actually do on the tablet.
1. can I assume the loader file is what makes the flash active, bootable?
2. does the parameter file flashed with rkbatch tell the tablet what to boot and how, like the config file for grub or lilo more or less?
3. when flashing an upgrade file using rockchipbatch, are either of those two areas touched normally? (parameter and loader addresses on the flash)
4. the boot file, is that just the boot logo? or is it something completely different.
5. is cwm or factory recovery affected by the parameter file?
6. rock usb mode, i get into it and out of it with key combos. can I assume thats hardware driven? can I kill that flashing the wrong files?
7. I am guessing my biggest issue right now is the parameter file. if my assumption of what that files purpose is, is correct, would anyone agree thats my issue now?
8. can a parameter file be generated using my nand backups?
I can flash images and the tablet reacts in different ways but never a screen. some put it into maskmode, some to rockusb and I have found one that appears to even boot to usb storage after several minutes after flashing. all of which can be put into rockusb mode using hardware keys.
the unit doesnt appear to be dead, just fubared.
any input would be great.
Thanks. sorry for the babbling post, just looking for some clues.
