HTC sync is not meant to update Android. Plus if you have a non updated Magic, look around this forum before you do. There are many reason to NOT use the ROGERS update. Other forum dwellers will probably give better answers than mine be patient !
Rogers will cut data connection until you do their update, but it is probably easier to ROOT if you do not do the upgrade.
If i Root it, will they still cut off my data?
ok, that's what i want to hear.
So the latest 6.0 cyan is best for htc magic now? is it on 2.1 or 2.2 kernel?
thanks
