Root [ROM] 11/12/12 Cm10 hox+ international
Lloir
CyanogenMod 10 is a free, community built distribution of Android 4.1 (JB) which greatly extends the capabilities of your phone.
This is an Unofficial release.
install kernel
full wipe
flash rom
flash gapps
reboot into rom
Code:
#include
 * Your warranty is now void.
 * I am not responsible for bricked devices, dead SD cards,
 * thermonuclear war, or you getting fired because the alarm app failed. Please
 * do some research if you have any concerns about features included in this ROM
 * before flashing it! YOU are choosing to make these modifications, and if
 * you point the finger at me for messing up your device, I will laugh at you.
CM10 Issues thread
Working:
Display
Wifi
Lights
Sensors
GSM+DATA
GPS
MTP\Sdcard
AUDIO
Menu button
Camera
NOT WORKING
you tell me
** Downloads **
DO NOT USE CWM RECOVERY I WILL NOT SUPPORT IT IF YOU USE CWM YOU WILL LOSE YOUR SDCARD STUFF. BY DOWNLOADING THIS ROM YOU HAVE READ THIS WARNING AND FLASHED TWRP RECOVERY
USE THE BOOT.IMG linked below, it's a modified blade kernel which WORKS with this rom and ONLY THIS kernel
DOWNLOAD
boot.img
GAPPS
Come join us on IRC
Please ask my permissions if you wish to use this rom as a base for anything.
Thanks to
Maxwen for getting me a good kernel for 10
rogro82 for pointing me towards an easy fix for a linker error
both been epic!!
All of the following people for donating
Code:
orb3000
morphly
hasoon2000
hasan_abeer
vogi
chrigel2000
AndroHero
ectodroid
ALF@be
Anon #1
Ixz
bboerny
Anon #2
Anon #3
sellers86
Wik
Anon #4
simonsimons34
caedanne
flipside101
morphly
bboerny
And the CM Team
CHANGELOG
Code:
11/12/1
Camera fixed
Menu button fixed (task switcher is long press home you can change this yourselves in settings > system > hardware keys)
And general CM updates
10/12/12
CM updates
Audio fixed thanks maxwen
7/12/12
Initial release
