Ok, so wiped Chevy's new 2.1 rom and tried this one.. same result. Mobile data connection will not initiate so I get no data unless I use WiFi.
Actually.. after checking the girlfriend's Eris.. it seems the 3G issue is something with the network as her stock phone isn't connecting either. Damn Verizon.. wonder how long this outage will last..
I was doing the same thing this morning, but didn't have another phone to check to see what the problem was. Finally went back to how it was last night and then the network came back up, anyone know how long it was down for?Actually.. after checking the girlfriend's Eris.. it seems the 3G issue is something with the network as her stock phone isn't connecting either. Damn Verizon.. wonder how long this outage will last..
So annoying.. I've wiped and reinstalled about 6 different roms trying to get mobile data to work before I bothered to check her phone..![]()
I installed this. I lost some of my paid for apps (like Touchdown). Furthermore, I can't even find them on the app store to purchase these again. I have tried to post this on the treat at alldroid but I am not a registered member and am waiting to be approved. Could someone post this over there for me? Otherwise- fantastic rom and it is SUPER fast after adding the OC kernel!
Thanks,
Josh
ChevyNo1 said:Try this:
- adb pull /system/build.prop
Then I edited it to comment out the fingerprint line, and add...
CODE
ro.build.fingerprint=verizon/voles/sholes/sholes:2.0/ESD20/17572:user/ota-rel-keys,release-keys
Then I pushed the build.prop back...
- adb remount
- adb push build.prop /system/build.prop
Fabdroid- Thanks for the response. Unfortunately, that sounds a bit out of my league. Do you think this is something the DEVS will be fixing. If so I can just wait. I actually pulled all the apps of of titanium backup. They are still not showing in the market place but at least I have them on my phone so I can wait for the devs to fix this if they are going to.
Thanks,
Josh
I ran into that with the Ultimate ERE25 build last night as well, and flashed back because of it. Good to know it's an easy fix at least.Yeah, no doubt it will be fixed in future releases. It's just one line of code.
I don't think any of the dev's anticipated that the ERE25 build wouldn't be able to download the "protected" apps from the market.
Thanks,
Josh
I believe Chevy posted an update.zip that fixes it in his thread at droidforum:
[2.1 ROM - 1.25Ghz] SS MAJOR Beta ERE25 Build - (3/1/2010) - Page 8 - Droid Forum - Verizon Droid & the Motorola Droid Forum
I installed Chevy's ERE25 and the patch update.zip from above, Market is still broken.
Wow - wouldn't have expected that, thanks for letting me know. I still have Simply Stunning 2.0 with the patch on, I will just keep it there for a bit and see if it resolves. Not sure I like the theme, but I can live with it for the time being given how fast this build is compared to other 2.1s - it's really amazing.It took my phone almost 12 hours to recognize the change in the build.prop file (made by the update.zip), but I did get my protected apps back.
OK, I did a nandroid advanced restore to install this last night and re-installed all of my apps using the Titanium Backup app. None of them are showing as installed when I go to the market, but when I go to each app in the market on my own, they show as installed. Does anyone know if I will get app updates pushed to my phone or am I going to have to hunt them down myself?
Also, has he put a patch in for metamorph theming yet? I can't stand the stock look. I will say this though, the phone is running alot cooler using this ROM than the last 2.0.1 BB I had installed. The Chevy Kernel is really nice. It's a very quick ROM. Other than the issues I mentioned, I like it so far![]()
If you are worried about program updates not coming through you can download AtrackDog which helps monitor app updates
