Do you have the files? I can't find lunar gem rom post I found it in the rom collection but says page not found
My ROM has init.d support so you can most definitely install v6 supercharger if you want.
How does one go about this process?
Hey spzo did you change the status bar open android banner smaller?
Lol dude I have no idea of fixing this xD I was hoping if you tell me copy the mdip drawble status bar and replace it and the system files
ha i mess with that status bar myself and i just copy and replace the systemui.apk and it work for me i got ics theme idk how i did it but i am loving it![]()
Lol like I said I have no idea all I did was copy and paste every file in system ui res drawable mdpi
I don't have the files no more if you want I can do it for youall I did was copy and paste everything that says status bar xD
Hey bro all I did was extract ics rom status bar pr the systemui unzip it and then I just copy and paste in your rom and flash it
Make a backup first!!!!!!
Here is the steps I did download the oa rom and get paris ics thene or my theme just unzip go to system /app / system ui and extract it go to the systenui and go to rez draqable mdpi and copy all pics that says status bar I try to put the battert icons and no effect it will only change the status bar when you draw it down the bar won't be transparent just dark blue and zip the file and remane systemui.zip to systemui.apk and replace it and system/ app/ and paste and zip thee whole rom and have happy flashing oa rom![]()
No problemha I did this method on my own and I got scare I was gonna brick it I am barely new to android but I wanna be a dev but first I need to know how a rom works and functions lol
