JB in AZ
Android Expert
Calkulin's EViO2 v1.8
This is a Sense based ROM from accomplished dev, Calkulin. He included many nice features:
ROM includes:
HTC 2.6.32.17-gee557fd #15 kernel(undervolted)
Most HTC apps
ADW Launcher
EStrongs File Explorer
Facebook
HTC_IME mod
Quickboot
Wireless Tether
Busybox
and a couple more
(Removed apps are in the sdcard/Removed_Apps folder)
MODs included:
Tweaked system(Very FAST)
Unlocked 3G USB tethering & Sprint Hotspot!
Moved dalvik-cache to cache partition
Reduced auto-brightness range for better battery life
Disabled search button(Enable zip attached)
Removed haptic feedback from dialer & stock Android lockscreen(if you decide to use it)
Notification bar will display TRUE network speeds(2G(1x) when used), instead of always 3G(EVDO)
Battery % on battery meter(ported from Smooth Icons)
Removed USB Debug notification
Removed purple hue from most of Sense
Colored notification icons
Rosie app launcher displays 5x5 icons & swapped right button to launch the browser(ported from JsChiSurf's Rosie mods)
SNQ's 4-in-1 Reboot option mod
JsChiSurf's Notification Menu Power Widget mod w/ custom icons
Upped MMS size limit to 5MB(Default is 2MB still)
Modded Flash Player so Hulu works
Annoying ads in programs are blocked
System has also been de-odex'd, apk's have been optimized & aligned
ROM includes:
Most HTC apps
ADW Launcher
HTC_IME mod
Quickboot
Wireless Tether
Busybox
and a couple more
MODs included:
