Root [ROM][3-2]SD v 34 |4.19| 1st ANDROID 5.0+Sense Rom | SDkernel | SDHub | Best Batt.
SkyDragon On XDA Portal
FIRST M8 LOLLIPOP SENSE ROM
SkyDragon Kernel Benchmark
Android 5.0.1
HTC Sense 6.0
Latest Rom Version: SkyDragon M8 v 34.0 WWE International
*Variants Support: GSM
*Made From Scratch
*Rooted with SuperSu powered by Chainfire
*Debloated
*Added Full Language System Support
*Deleted HTC Spywares
*SDHUB
*SkyDragon Bootanimation
*Updated Sense Apps
*SD Kernel 3.1.2
*SD Density App By Skeleton1911
*Set 27mhz as default gpu clock speed
*Turned off zram
*Fixed up kexec hardboot patch
*longpress backkey kill app
*advanced power menu
*battery %
*sweep 2 wake/sleep
*clean all recent apps for Google card view style
*remove search bar from recents
*right corner pulldown qs
*15 tiles qs
*Project Era v23.1 (Thanks ZeroInfinity!)
*Init.d Built-in and Tweaks Added
*BusyBox Built-in
*AppOps
*Added Dropbox
*Added Latest Titanium App
*Speed Optimizations
*Battery Optimizations
*Removed and/or disabled all Logging apps & Files
*External SD-Card write support
*Google Apps Updated to Latest
*More Aroma stuff- added Jan. 17
--Fixed up some more removal options not working
--Added HTC Messages Removal
--pre-unchecked Tibu/poweramp/quickboot for removal
--Added GPE Contacts/Dialer(Will replace/remove Sense contacts/dialer)
--Added Hacked Exchange Mail apk option(No pin/password required)
--Added Lyapota's Modpack v001 (APM/Clear all recents)
*Added SDHUB
*Added a few more scripts to build.prop
*Added Additional Default Theme options in settings
*Added flashlight to quick settings pulldown
*Aroma by @HolyAngel
SkyDragon On XDATV
SkyDragon M8 Rom Android 5.0 By dragonesdenano/HolyAngel - Video Review By jureca
SkyDragon M8 Rom Android 5.0 By dragonesdenano/HolyAngel - Video Review By Imotep95
SkyDragon M8 Theme For Android 5.0 By MauryDes - Video Review By jureca
If you like OUR work and Dedication don t forget to press Thanks, and Give Us a Five Star Rating!!!!
Donations are not expected, and all will have the same kind of love here, there is no such thing as noob or silly questions, just be yourself!!!
SkyDragon M8 Android 5.0
v 34 International WWE
Moved to a Rock Solid Base
Still Euro, 4.19.111.2 Will Work For All GSM M8
The Base Was Hacked to be Free Carrier.
Aroma Was Cleaned, Old Apps or new ones
Updated SkyDragon Kernel to v 3.1.2 By HolyAngel
SkyDragon Sense 5.0.1 Kernel
~*Made from scratch by HolyAngel*~
V3.1.2
*Turned off zram
V3.1.1
*Fixed up 268mhz cpu clock speed
*Added 100mhz gpu clock speed step and set default speed to that
*Compiled with latest Linaro 4.9.3 Toolchain
*Updated all modules to latest compilation
V3.1
*Remade Wake Gestures from flar2's Sense 501 kernel
Added New SkyDragon Bootanimation By Lookinen
Added APM Advance Power Menu
Added Back Key Kill App
Added Clear Button in Recent Apps
Added Home Menu Key
*Personalize - Wallpapers - Sound - Notifications - Quick Adjustments - APM - Settings
Added Flashlight to EQS-Extended
Tap Right Upper Side Of Notification Bar Brings EQS-Extended
Added 1% Battery Mod
Added Exchanged Mail
Updated ZeroInfinity Sound Mod To 23.1
Project ERA v23.1:
-Fixed NEW (Generic) Dolby Digital Plus "Play Demo" sound (Thanks to [MENTION=5625510]kansasboy001[/MENTION] for alternative fix!)
Project ERA v23:
-Added a new Dolby Digital Plus, officially from Dolby (Thanks to [MENTION=5648292]aki_007[/MENTION] for getting the port working without framework modifications, Thanks to [MENTION=5813230]riyono[/MENTION]/@ocoot for the files/tutorial)
-My custom config for Movie preset in Dolby Digital Plus, you can customize any preset, anytime
-Moved things around in AROMA Installer (More features are put into options)
Updated OEM Apps
Updated HTC Apps
Updated Google Apps
Removed Quic Boot App
Removed V4A and XHIFI Apps
Removed chrome Broswer...
And...
Few More.
v 33 International WWE
Ported All From v 32.0 To Euro Base 4.16.401.10
Using Ruu.exe Someone Sent to my mail.
Added New SD App> SD Density Changer by Skeleton911
Updated HTC Apps
Updated Google Apps
Updated OEM Apps
Few More
v 32 Dev Edition
Not posted in Op , Public Beta
V31 WWE International
*Fixed BlinkFeed Forced Closed
*Fixed Others Non Working Apps
*Added More Tweaks for Battery and Performance
V30.0 WWE International
*Made Using System Dump 4.16.401.9
Credits and Thanks to LlabtooFeR
*Made From Scratch By dragonesdenano
*Ported All To new Base
*Integrated Lyapota's Modpack v003
*Fixed AppOps FC
*Added Woodstock s Flashlight Fix for EQS-Extended
*Added dmonium s Transparent WeatherClockWidget as Option in Aroma
Credits and Thanks to dmonium
*Added ckpv5 s Transparent MusicWidget as Option in Aroma
Credits and Thanks to ckpv5
*Added More Tweaks to the rom
*Things I forgot cause its 3.14 am
V29.0 Developer Edition
*Aroma fixup for better user experience
--No more inverted splash screen
--Thanks/Credits fixed
--Fixed up mounting script so twrp should no longer have ANY issues
*Integrated Lyapota's Modpack v002
*battery %
*change navbar size (48/42/36/32 dpi)
*sweep 2 sleep
*centered clock
*15 tiles qs
*Added AppOps option
*Tweaked build.prop a little more
*Added Sweep2sleep module by lyapota for stock kernel only
*Removed HTC Spyware apk's and libs
*Fixed Google Maps removal
*added HTC Power To Give removal option
v28.0 Developer Edition
*More Aroma stuff
*Added SDHUB
*More I'm sure I'm forgetting..
SDHUB Changelog For SkyDragon M8 v 28.0
MODS SECTION
*SkyDragon M8 GPE Rom - By HolyAngel (Thread Link Added)
*SkyDragon M8 RedBulled - By joni2012 (Thread Link Added)
*SkyDragon M8 v Sense Rom - By dragonesdenano/HolyAngel (Thread Link Added)
*SkyDragon M8 GPE Kernel v 3.0.7 - By HolyAngel (Download link Added)
*SkyDragon M8 Sense Kernel 5.0.1 v 3.0.7 - By HolyAngel (Download link Added)
*SkyDragon M8 Sense Kernel Stock 5.0.1 - By HolyAngel (Download link Added)
*SkyDragon Horizons - Official Themes - By MauryDes (Thread Link Added)
*Some Old School Mods - by ckpv5 (Thread Link Added)
*Full Conversion Of Your M8 To Any Variant -Guide- By exocetdj (Thread Link Added)
*Ruus, OTAs,Stock TWRP Backups, Firmware & More - By exocetdj (Thread Link Added)
*ModPack For M8 Sense Rom Android 5.0.1 - By laypota (Thread Link Added)
*ModPack For M8 GPE Rom Android 5.0.1 - By laypota (Thread Link Added)
*How To Unlock/Lock Your Bootloader Without HTCdev - Guide- By scotty1223 (Thread Link Added)
*VomerGuides M8 Bootloader, Unlock, S-OFF, SuperCid, Firmware Upgrade & Custom Recovery - By vomer (Thread Link Added)
*Fonts Paradise - Sense Fonts - By mushages (Thread Link Added)
Wallpapers
*Added More than 100 Wallpapers
v27.0 Developer Edition
*Aroma updates
-- Removed useless options for apps that didn't exist
-- Added removal for various apps like htc club
-- Added Project Era v22 (Thanks to ZeroInfinity!)
-- Added SD Kernel 3.0.7 (YouTube issues with this kernel)
-- Added latest Titanium Backup
-- Added Power Amp
-- Added Quickboot app
-- Added Dropbox as it was missing
*Updated google apps
*Updated gallery
*Updated busybox
*Added all language support in the rom
*Added Permission fix for SDCard Read/write
*Updated Build.prop
v26.0 Developer Edition
*Rebased to Latest Android 5.0 - 4.16.4510.8 Dev edition using official HTC ota.
*Made From scratch by HolyAngel
*Ported Aroma
*Init.d Built-in
*Busybox Built-in
*Rooted with SuperSu 2.44
*Debloated.
*Few More and More Soon!
HTC Changelog
*Android 5.0 Lollipop Update
*Lockscreen and Notification> New Lollipop UI style
with enhanced privacy features
*Recent Apps> Supporting multiple pages
*Addition of search function within settings
v25.0 Developer Edition
Ported All To Base 3.28.1540.5 Developer Edition
Updated SkyDragon Kernel to 3.0.6
*Optimized Kernel Samepage Merging
*Disabled add_random for better performance
*Fixed permission for Power Efficient Workqueue
*Full VFP4 throughout kernel
*Fixed 2 SELinux bugs
*Optimized sheduler to avoid excessive loadavg
*Enabled sysfs interface to control Gentle Fair Sleepers
Updated OEM Apps
Updated HTC Apps
Updated Google Apps
v24.0 WWE International
Updated SkyDragon Kernel By *HolyAngel*
V3.0.3
*Built with latest 4.10 SaberMod Toolchain
*Enabled Linaro Power Efficient Workqueue's
*Enabled Arch_Random for better entropy/Security
*Enabled Kernel Same-Page Merging and checking
*Fixed up fair scheduler for better performance
*Fixed up High Performance Sound not sticking
*Enabled Quad Core Stats for FauxClock IdleStats
*Kernel and Ramdsik compressed with LZMA for better speed/Smaller size
Updated Oem Apps
Updated HTC Apps
Updated Google Apps
Happy Christmas ALL!!!
v23.0 WWE International
Minor Fixes
Updated HTC Apps
Updated Google Apps
Updated OEM Apps
Updated Xposed Mods
Added V4A Sound Mod!
v22.0 WWE International
Credits and Thanks To GraveDigger176 For Nandroid
Latest HTC Base 3.28.401.9
Ported All from SD v 21.1
Fixed SD Kernel Aroma file
Added New Google mail App INBOX
Few More
V21.1 WWE International
Updated SkyDragon Kernel to v 3.0.2
*Built with latest 4.9.3 Sabermod Toolchain
*Added High-Performance Sound
*Overclocked Slimbus for better audio
*Entropy fixup
*Optimized kernel
*Added Kexec Hardboot for Multi-Rom Support
Fix in Aroma
*Calculator.apk From System/App to System/Priv-App
*Android L KeyBoard
*Google Play Kiosco
*HTC Power To Give
*Power Amp
*Screen Filter
*Skype
*TrickterMod
Updated HTC Apps
Updated Google Apps
Updated OEM Apps
Updated Xposed Mods
Updated Gplay app To Latest v 5.0.38
V20 International WWE
Same Base 3.28.401.7
Added SkyDragon Kernel
*Updated to latest Dev Edition 4.4.4 Source Code
*Removed Intelli-thermal
*Removed Intelli-Plug
*Removed ZRam
*Max clock set to 2.45GHz for compatibility
SD Kernel is an Aroma Option
Added Xtended Settings 1.2.0 By "Master" RichmondoUK Here his Own Thread > Link
Added Crop In Mode to Camera
Updated HTC Apps
Updated Gapps
Updated OEM Apps
Added Android L Keyboard Thanks to tigerstown!!!
Minor Fixes in Aroma few less
V19 WWE
Ported all From v 18 to v 19.0 WWE
Using GraveDigger176 Nandroid
New Base 3.28.401.7
V18.0
Using GraveDigger Nandroid Backup Credits and Thanks to Him!
Android 4.4.4
Sense 6.0
Base 3.28.401.6 WWE International
*Important > Select Only STOCK UNSECURED KERNEL in Aroma *SD Kernel needs to be updated!
Updated HTC Apps
Updated Google Apps
Updated OEM apps
Updated Aroma
Rooted With ChainFire SuperSu
Busybox built in
Tweaked for best Performance and Battery Life
Rom Requires Latest Firmware Android 4.4.4
Minor changes not big deal
V17.0 International-Dev Edition-Rogers
Added New Kernel options
*Stock unsecured
*SkyDragon Kernel v 2.0.3.6
*SkyDragon Kernel v 2.1.0.1 may not boot for few users
Updated HTC Apps
Updated Oem Apps
Updated Google Apps
Updated Xposed Apps
Fixed Aroma Kernel Related bug
Fixed again SuperSu for all kernels
Added New SkyDragon Bootanimation by pkoper!
Updated Tweaks and minor changes!
Rom should fly now and you may get best battery again!
Not much Else
V16.0
Private Beta
Based on Firmware 2.23.631.2 Best US base for now
Added SkyDragon Kernel Android 4.4.4
*Stock Cpu Frequency is 2.4 with Oc possibility To 2.8 Ghz
*This kernel may not boot for all, if bootloop flash provided kernel in Opp
*This Kernel has lots of customizations like STW among others
Fix Some Broken System Tweaks
Added Few new tweaks
Updated Google Maps
Added Screen Filter app to get More Screen On Battery
Gplay and Google Services updates were moved to System/priv-app
Added Updated Tweaks
V15.0
Made From Scratch
Ported All to new Base 2.22.1540.4 Dev Edition
Using my own clean Nandroid Backup
Stock Unsecured Kernel
Updated OEM apps
Updated HTC Apps
Updated Gapps
V14.1
Removed SkyDragon Kernel From Aroma
Rom has Stock unsecured Kernel
Fix GoogleTTS and TalkBack removal in aroma
Few System Improvements
Added SDHUB..Still no content on it but Soon!
V13
Skipped as Bad Luck Number
V12.0
Ported all to Latest Base 2.23.631.2 Rogers
Fixed Aroma Removal for Some Apps
Updated HTC Apps
Updated Google Apps
Updated OEM Apps
Fixed Root / SuperSu Chainfire For Stock Kernel
V11.1 Beta Discharged
Updated HTC Apps
Updated Google Apps
Updated OEM Apps
Added To Aroma Center Clock + 1% Battery Mod
V11.0
Updated SkyDragon Kernel To latest Version
Added Possibility to Select Stock Unsecured Kernel
Added Possibility To Dissable EQS-Extended Quick Settings
Updated Oem Apps
Updated HTC Apps
Updated Gapps
Added New Mods in Aroma By ckpv5
*Transparent 4x1 WeatherClockWidget
Weather Clock Widget with white text and white weather icons
*Transparent NavBar StatusBar
Transparent both NavBar and Status Bar, come with transparent folder with small white outline and semitransparent home expanded panel
Updated Softkeys Mod too!
Minor changes
SkyDragon M8 Android 4.4.3 Dev Edition 2.22.1540.3
V10.0
Ported All To New Base 2.22.401.4 WWE
Updated SkyDragon Kernel, Still v 2.0.3.5 By HolyAngel
*Wake up Gestures
-Sweep2sleep
-Sweep2wake
-Double tap
*Sweep left to right
*Sweep right to left
*Bi-Directional Sweep
*Sweep up
*Sweep down
*All Gestures
*Pocket Detection
*Disable Camera Landscape Volume Buttons
*Enable USB fastcharge
*Disable fsync
Added To Aroma HK Sound Mod
Added More Removals to HTC apps
-HTC HTC News
-HTC MocanaKey VPN
-HTC PowerToGive
-HTC AndroidHtcSync
Fix Non Installing Xposed Apps in Aroma
Updated Oem Apps
Updated Google Apps
Updated HTC Apps.
Fix Few Errors in Aroma
V9.1
Fixed Wifi error in Kernel
*About The kernel
-Still Version v 2.0.3
-Faux Sound Control
-HD Audio
-High Perfomance headset
-LCD Kcal control
- Among others
Few Updated Apps
Re Added SkyDragon Bootanimation
Added dotview, Battery% and Android L Softkeys Xposed
Fix few Removals in Aroma
few more thingies
V9.0
Rom Based on Official HTC OTA
Firmware 2.22.1540.3
Provided by dragonesdenano
Ported most to this new base
Added SkyDragon Kernel v 2.0.3 By HolyAngel
Monor fixes
And More
V8.1
Added SkyDragon Kernel Clocked at 2.8Ghz
Deleted MiniSense Lockscreen Xposed
Deleted Battery Xposed
V8
Added SkyDragon Kernel V2.0.10
Added Smaller Softkeys Mod to ARoma By ckpv5
Added Circle % Battery White Mod to Aroma by ckpv5
Deleted OppApp Xposed
Added Sense6 Battery Xposed
Added Mini SenseLockscreen Xposed
Updated Oem Apps
Updated HTC Apps
Updated Google Apps
Few More
V7.1
Updated Oem Apps
Updated HTC Apps
Updated Google Apps
Updated Xposed Apps
Updated SuperSu to latest
Removed Chrome
Added Flashlight
Added HTC Task manager
Added HTC File Manager
Added More App Removals in Aroma
Added Xposed Mods Sense Lockscreen 6 and OppApp
Minor Fixes
V7.0
Android 4.4.3
HTC Sense 6.0
Thanks And Credits to Football for System Dump!
Firmware base: Dev Edition 2.12.401.3
Rom Version: SkyDragon M8 v 7.1 International
*TMO WifiCalling Not Supported
*NO Verizon
*No Sprint
*Made From Scratch
*SkyDragon Kernel V 2.0 By HolyAngel
*Deodexed - ART Still Works
*Zipaligned
*Debloated
*Native EQS
*Updated Sense Apps
*Bionic Libs from KVT49L for Supreme Speed
*BusyBox Built-in
*Pie Control
*Xposed
*GRavity Box
*Sense 6 Tool
*Xblast
*XHalo
*XuiMod
*youTube Away
*Many Build.prop Tweaks
- Speed Optimizations
- Battery Optimizations
- CarrierIQ Free!
*Rom Zipaligns on boot
*Rom Optimizes SQLite Databases on boot
*OpenVPN Built-in
*MMS message size increased to 1000k
*Few More
V6.0 International
Changelog
*Updated SkyDragon Kernel to version 0.4
-Max frequency to 2.45ghz instead of 2.26
-Added extra governors, lagfree/Lionheart/smartassV2
-Minor Fixes
-Updated Supersu to latest v 2.0 Powered by Chanfire
-Cleaned Aroma
-Updated OEM Apps to latest
-Updated Gapps to latest
-Updated HTC Apps to latest
-Updated Xposed Installer and Xposed Modules to latest
-Remember this Rom is using ART+Deodex, since v 1.3 Version
Like two months Ago at least. We did it! yes, oldnews!
few more i forgot due to my pilz and Rbulz!
V 5.0 International
Ported all To International Firmware base 1.54.401.10
Using Clean Nandroid Backup from GraveDigger176
V5
*Based on SkyDragon M8 1.55.631.4 Rogers Edition
*Added Variants Support
-Att(Sprint-Tmo-Vzw < Not Working Yet)
*Added Carrier Support
-3 Italy, 3 UK, ATT, Bell, Megafon, O2 Germany,
-O2 UK, Rogers, Telstra, Telus, Tim Italy,
-Tmob, Tmob Germany, Tmob UK, Vadafone Australia,
-Vadafone UK, Vadafone Italy, Vadafone Germany,
-Wind, Wind Canada or you can Skip all.
*Added APM
*Added HTC TaskManager and HTC FileManager
*Moved Flashlight and Calculator To System/Priv App
*Updated Elemental X Kernel
*Added SkyDragon Rogers Kernel v0.3.1
*Disable Signature Check in Services.jar Properly
*Removed from Data/app folder JControlHeadset
V4.1
Removed All variants in Aroma
added more removal for some apps
-Added SkyDragon Kernel By HolyAngel
*It is completely based on stock Sense source*
*Compiled with Linaro 4.7.4 toolchain
*Full -02 Optimization plus some extra flags for further performance and specific optimization
*Added Schedulers: BSG/FIFO/FIOPS/SIO/TRIPNDROID/VR/ZEN
*Added Governors: Adaptive/DanceDance/Intelliactive/Intellidemand/Interactivex/Wheatley
*Tweaked deadline scheduler
*Tweaked Ondemand governor
*Overclocked slimbus
*Added Overclocking and Undervolting capability
V4.0
Ported All To Latest HTC firmware 1.54.401.10
Using Clean Nandroid Back up
Cortesy of GraveDigger176!
SkyDragon M8 Dev Edition
V3.1
-Updated Elemental X Kernel To 0.16
-Updated ZeroInfinity Sound Mod to 16.2
-Added Kernel Tweak App
-Added Clean Master
-Added Xposed Greenify
-Updated SenseToolBox 6
-Updated Blinkffed by HTC
-Fixed Widgets removal
-Added New apps For removal in Aroma
-Minor Fixes
-Others Variants must be tested
V3.0
Ported All to International Base
From SkyDragon M8 Dev Edition
Still Nightly
V2.4
*Updated Kerne Elemental X to v 0.12
*Updated Google Apps
*Updated Htc Apps
*Updated Gravity Box 3.1.2
*Added LMT
-removal option
*Added SideWindows Swapps
-removal option
*Romved Google Chrome From System/app Folder
*Removed Magazines.apk from Data/app Folder
*Removed Tether.apk from Aroma
*minor fixes
*T-mobile FC Fix sort of. By Clarkkent434
work around till the T-mobile version is fix. When you flash just select dev edition instead on T-mobile version and it work just fine. No FC now and Wifi calling is working too.
V2.3
*Based on SkyDragon M8 v 2.2 Dev Edition
-Att-Sprint-Tmo-Vzw
*Added APM
V2.2 Beta
*Based on SkyDragon M8 v 2.1 Dev Edition
*Added DPI Option Selection In Aroma
-480
-440
-400
-370
*Fixed Some HTC auto updating from GPlay
*Removed Tethering App, Wasnt working
V2.1 Beta
*Based on SkyDragon M8 v 2.0 Dev Edition
*Re Added Missing Google Apps
*Updated Busybox to latest
*Added SkyDragon Bootanimation
*Added Harman/Kardon Sound Mod in Aroma Selection thanks Laypotia/HolyAngel
*Updated Sense Apps
*Updated OEM apps
*Fix Small Bugs
*Added Titanium Backup
*Added Quickboot app, no need to press Physical buttons
*Added JayHeadset Controll, You can skip tracks with HTC Headphones
V2.0 Beta
*New Clean OTA Dev Editon 1.54.1540.9
*Made From Scratch
*Zipaligned
*Debloated
*Services.jar Patched
*1% percent Battery Mod
*Native EQS
*Updated in Kernel Aroma Selection ElementalX 0.10
*BusyBox Built-in
*Rooted w/ SuperSU 1.94
- CarrierIQ Free!
*All APK's Zippaligned
*OpenVPN Built-in
*Turned off Signature Verification
*System Read/Write
*Sweep2Sleep Navbar module
*Keeps Same Aroma Options as latest SD m8 Version
*Things i forgot!
Thanks to HolyAngel, fisha and v-b-n
SkyDragon M8 International Edition
International V1.3
*Deodexed Rom - ART STILL WORKS!
*Added more keyboard options in Aroma
*Added Sense 6 Toolbox v1.0 option in Aroma
*Added Project ERA option in Aroma
*Added SoundExplosion option in Aroma
*Disabled Signature Verification again for full theme support (Should get those soon!)
*Cleaned up some xml's
*Fixed an issue with HTC Backup getting messed up during HTC app removal
v 1.1
Mainly Added Elemental X kernel as an option to aroma
minor fixes
V1.0
*Based on our own 1.54.401.5 Stock NAND (V1rk)
*Fully Deodexed for Theme Support
*Latest Aroma Installer (HolyAngel)
- Xposed!
- App Removal
- Widget Removal
- GAPP Removal
- Keyboard Selection
- Font Selection
*BusyBox Built-in
- CarrierIQ Free!
*OpenVPN Built-in
*System Read/Write
v 2.0
*Added EQS
*Added Sweep2Sleep from Flar2
*Added Full Theming Support (patched services so any sense 6 theme we have out will work on it)
*Fixed System FC on startup
*Fixed Gallery FC
*Fixed showing Selected Font in Aroma
v1.0 Att base
*Based on ATT 1.12.502.18 Stock NAND
*Removed most all ATT apps
- Xposed!
- App Removal
- Widget Removal
- GAPP Removal
- Font Selection
*Init.d Support and Tweaks
*BusyBox Support
*SuperSU 1.94
*Build.prop Tweaks
*Removed all Logging apps & Files
*Added External SD-Card write support
*Zippaligned
*Zipaligns on boot
*SQLite Optimization on boot
*Sysro/rw
*OpenVPN Support
SD Kernel By HolyAngel
Kernel source for SkyDragon kernel:
SkyDragon M8 Kernel Source
HTC Kernel Source that its built off of:
Link
SkyDragon M8 v 34.0 WWE International ANDROID 5.0
3-Feb-2014
AndroidFileHost
SkyDragon M8 v 34.0 International WWE
md5 cedae47d54860094efad5152b1012246
HTCfanboys
Gdrive
Firmware Zip Android 5.0 Dev edition 4.16.1540.8
Recovery and Boot.img were removed!
Firmware
In Fastboot mode and your M8 connected to your PC
Type via Fastboot the following terminal commands...
fastboot oem rebootRUU
fastboot flash zip firmware.zip
then again a second time
Stock kernel zip Android 5.0.1 Dev Edition 4.16.1540.8
Wipe cache and flash via recovery
Stock Kernel
For more details on flashing firmware see User Guide And FAQ section below
Credits and Thanks To GraveDigger176 and V1rk For Mirrors:good:
Dragonesdenano -Leader- XDA RC
HolyAngel -Dev- XDA RC
matiasTorres - Dev For M7
Alex-V Dev-Themer
Ram09 -Tester-Backups-
V1rk -Tester-Backups-
2WiLfIrE -Themer-
MauryDes -Themer
joefrank -Themer-
kelvin216 Themer-
jeryx -Tester-
GraveDigger176 - Tester- Mirrors- Futbol
exocetdj - Tester- XDA RC
HC4Life - Tester
PhillyFlyer - Tester - Graphics
badboy47 - Tester - Graphics
jureca - Emotional Support - Social Networks
kalimpula1 - Tester
touchy - Who knows? :p
Fer Alvaro - Tester
Supervisor - Tester
Joshua - Tester
joni2012 - Dev
thunder007 - Dev
Pkoper - Graphics
locklear308 - Tester
Bobbi Lim - Dev-Tester
liam_davenport - Tester
webcd - tester
*mj13* - tester
nightservant - Banners - web - tester of Rbulled
HolyAngel for Aroma Magic!!!
seyidaga And Ronald - SD Wallpapers, Banners and Bootanimation
Lesscro For Logo, Banners and image host http://imghost.lesscro.com/
SD Team
Our Testers
LlabtooFeR For System Dump! of Euro Lollypop
Laypota For His ModPack!
Fisha for his theming skills
ZeroInfinity For Project ERA!!!
Google&Linux
Dsixda
Team Virtuous VTS Kitchen
HTC
Xda, Xda Users and Mods
jeeko for Permformance Mod!!!
RichmondoUK for Xtended Settings, Here his Thread > Link
*V4A Sound Mod Credits To ViPER520 and zhuhang Also Check Official V4A WebSite Official V4A Thread
dmonium for Transparent Widgets
ckvp5 for his Mods!
woodstock for Flashlight fix in EQS
*If I forgot You pm me
effezie
exocetdj
V1rk
myrmidon84
Jeryx x2
jtommyj
MauryDes x2
Locklear308
09Ram
tattoomanz
ohyouknow87
09Ram
shiniyoyo
virk1
webcd
2WiLdFiRe
*mj13*
m8980
