b_randon14
Android Expert
CyanogenMod 10.1 | Android 4.2.2 JellyBean!!
[HIGH]#include <std/disclaimer.h>
* I am not responsible for bricked devices, dead SD cards, thermonuclear
* war, or the current economic crisis caused by you following these directions.
* YOU are choosing to make these modificiations, and if you point your finger at
* me for messing up your device, I will laugh at you.
*/[/HIGH]
This ROM is compiled from source. I started with the work of dastin1015 & Team-Hydra, and applied a mms fix, and more suited the source for the Virgin Mobile variant of the S2. I made this ROM so that we here at Virgin Mobile could just flash a ROM and not have to worry about fixing mms or resolving other little quirks, this ROM is built for Virgin Mobile!
Please read the entire first and second post before flashing this ROM!!
Features:
Whats Working?:
Issues:
Installation:
Credit:
Donate:
Notes:
General Information on the VM SGS2:
Source:
*/[/HIGH]
Features:
- Compiled directly from source
- Kept up to date with upstream CyanogenMod
- Kept up to date with upstream Team-Hydra/dastin1015 changes
- Includes a CM10.1 kernel with the latest CWM Recovery
Whats Working?:
- Calls
- SMS
- MMS
- 3g/4g - 4g turns on and off, don't live in 4g area so I can't fully test
- Audio - Is slightly quiter, this is a issue with any 4.2 AOSP ROM for the Epic 4g Touch
- Bluetooth
- GPS - Locks very fast for me, usually around 2 seconds
- Camera & Camcorder - Front and back
- Audio Playback
- Video Playback
- USB Mass Storage
- WiFi
Issues:
- Any CM10.1 issue present on the Epic 4g Touch ROMs
- Audio is slightly quieter than stock
- I have had it drop me to 1x a couple times, think its more modem related
- Some have reported MMS issues with large messages, looking into this
- 4g WiFi tethering is not functional, native or 3rd party
- Dock audio apparently doesn't work, but I can't test it
Installation:
- MUST USE A ICS OR OLDER MODEM!!
- Data will not work on a JellyBean modem like FL14
- Have a custom recovery installed (Kuban Kernel, Agats Repacked kernels, etc) (I flashed from the Kuban Kernel 0.2.5)
- Flash an ICS modem if you need to (I use the FL26 modem, the latest Virgin Mobile modem)
- Wipe data, system, and cache if youa re on any ROM besides this one!!
- If already on my ROM, wipe cache & dalvik cache
- Flash CM10.1
- Flash Gapps for 4.2.1 (Must do this everytime you flash this ROM!!)
- If you are coming from a previous install of this ROM, wipe data on Clock once booted up
- Reboot & Enjoy the awesomeness!!
Credit:
- Credit goes first and foremost to dastin1015, not only did he get CM10.1 to where its at for the Epic 4g Touch, he also helped me with my work as well. Donations should go to him before me!
- Team-Hydra
- CyanogenMod Team
- Epic CM
- Anyone who has helped me along the way with my development career!
Donate:
- dastin1015 Donation Link: Donation to dastin1015!
- My Donation Link: Donation to me!
Notes:
- To enable Developer Options and Performance go to Settings > About Phone and repeatedly press Build Number.
- Make sure you followed instructions before telling me my ROM doesn't work!
- Search through the thread for an answer to your issue before posting about it to make sure it hasn't already been answered!
- By now you should know that the kernel and recovery are tied together on this phone. This ROM uses a kernel compiled at build time specifically for CM10.1, and it includes a fully functional CWM recovery. If you are to flash a different kernel over it to get a recovery, you phone will no longer boot to the ROM, and you will have to reflash the ROM or at least reflash the CM10.1 kernel.
- In order to return back to your previous setup with you nandroid you made, what I would do is through the included CWM recovery, flash the kernel/recovery that you used to make the nandroid, then reboot to recovery and wipe data, system, cache and then restore your nandroid.
- The Team Win Recovery Project recovery v 2.4 for the Epic 4g Touch works marvelous with CM10.1 (will not work with any TouchWiz/stock/Samsung based ROM!!!), but in order to get it to flash you must edit the updater-script and remove all the device asserts at the top of the script, or add SPH-D710VMUB to it. I will try to post a modified version of the zip that will flash when using this ROM. Also TWRP must be "injected" into the CM10.1 kernel image, so when upgrading to a newer ROM, you must either tell TWRP to reinject itself, or do what I do and reflash the TWRP zip!
- If you are coming from FL14, you will inadvertently have the FL14 modem on your phone. This means that if you do not flash a ICS or older modem, you will not have working 3g at the least, maybe more stuff not working. This is just the way it is for now, so flash the FJ12 or FL26 (links for these modems in 3rd post!)modem, and all the modems that will work on our phone can be found here: XDA Modem Repository! and here are the Virgin Specific modems: rwilco12's Virgin SGS2 Section
Source:
- All the source for this ROM can be found at my SGS2VMU-DEV github account here: SGS2VMU-DEV Github
Thank You soooo much
