mtmichaelson
Hello all! Here it is Broken Out Rom for the LG Esteem!!! It has been fully cleaned out to decrease size and to increase speed. It will continue to be a work in progress! I hope you all enjoy!!!
What is this?
This is a very lightweight rom built both for speed and stability. This rom is based off of the latest LG update to Gingerbread 2.3.4 version ZVD. It is fully deodexed, and debloated. Almost all of LG has been replaced and as time goes by, I hope to remove the rest. Swype has also been changed to the newest Beta. A few items have been replaced with AOSP versions to increase speed and decrease size. Also included is the appwidgetpicker to clean that up.
Changelog
v 1.1
Rom:
Fixed Power Off Issue
Made Google Default Search Engine in Browser
Removed All Stock Bookmarks Except for Google
v 1.0
Rom:
Based Off of ZVD Gingerbread
Deodexed
Zipaligned
Heavily Debloated
Custom Boot Animation
AOSP Lockscreen
Power Menu Mod
Added CMScreenshot to Power Menu
Accurate Battery Mod
Center Clock Mod
Cleaned Up Notification Pull Down
Changed Low Battery Pop Up to 1%
CRT Screen Shut Off
Added ADW Launcher
Updated all Apps Including Google Play
Added AppWidgetPicker
Newest Swype Beta
Build.prop Tweaks
Init.d Tweaks
Loopy Smoothness Tweak
Added Sony Bravia Engine
Made My Own Host File From Several Sources to Block Ads
Blocked All CIQ Logs From Verizon and Google (Requires Reboot After Install)
Kernel
OC/UV Kernel
Overclock to 2.1ghz
First Boot is Set at 1.0ghz
Modified Undervolt to help battery
Added Smoothass and Smartass2 Governors
Added SIO I/O Scheduler
Added SLQB Allocator
Added SFB Net Scheduler
Changed From JHash2 to JHash3
Added ZRAM Swap (To Turn on Use Terminal Emulator, Type "su" to Gain Root Access, Then Type "zram enable" )
Added 2-Way Call Recording
Included tun.ko Module
Other Memory and Performance Edits
v. 2.1
HDMI Fix
Screenshots
Screenshots are from the Revolution
How do I install this?
1.) Download the .zip & make sure 4g is enabled.
2.) Place zip in external sdcard
3.) Back up
4.) WIPE DATA!!! (You do not need to wipe if already on BrokenOut!)
5.) Go to install zip from sdcard
6.) Select BrokenOutEsteem1.0.zip
7.) Do not wipe data after flashing!!!
8.) Reboot!
9.) To Block CIQ Logs Requires Reboot After Initial Boot
Technical Info
This rom includes edits to several jar files, xml's and build.prop edits. As time goes more will be done.
Downloads
Rom
v. 1.1 Dev-Host - The Ultimate Free File Hosting / File Sharing Service
v. 1.0 Dev-Host - The Ultimate Free File Hosting / File Sharing Service
Kernel
v. 2.1 http://dl.dropbox.com/u/54501789/Esteem/BlitzkriegEsteem2.1.zip
Uncenter Clock
http://dl.dropbox.com/u/54501789/Esteem/UnCenterClockEsteem.zip
Special Thanks!!!
ldrifta for testing
mrpnut for testing
Donations
For those that enjoy the work that I have done and would like to support my efforts financially through the donate to me button, any amount is appreciated, but all that I ask is that if you like my work, please hit the thanks button!!!
