Meticulus, to whom was your post directed?Your attitude makes me wonder why I should bother with this device. I don't mind bug reports but you could say thanks before you start complaining.
If this is referring my post at thread post #25, I was thinking that it was your determination that their was an issue with Offline Charging. I had gathered this idea from your post at thread post #2, stating, "Offline Charger options via "Extras" do not work.", in the list of Known Issues.P.S. Offline Charging works perfectly.
I do not know what this code, acronym, or symbol means.NFIAJ
I'm not going to work on this for a while. Shame, I was planning to bring up MM.
NFIAJ
i copy some music yesterday and no issuesAlright, let's take it one thing at a time. What is wrong with MTP? I was having an issue with copying files to the internal storage: download folder but I deleted the folder and recreated it and now it's fine. Strange I know, but that is the only issue I have had with it. Now it's fine... So what problems ( if any ) is anyone having with it?
As of the current 20160728 build plus Update 1, MTP seems to be working rather well. The only issue I have with it is when files are uploaded to the Samsung SGH-T599N device via MTP, file timestamps are not retained.Alright, let's take it one thing at a time. What is wrong with MTP? I was having an issue with copying files to the internal storage: download folder but I deleted the folder and recreated it and now it's fine. Strange I know, but that is the only issue I have had with it. Now it's fine... So what problems ( if any ) is anyone having with it?
That would be great. I do look forward to it.I will have "Phone Encryption" completely fixed next release.
An issue I do have is that when "Mass sorage (UMS)" is selected in the "USB computer connection" options (Settings --> Storage -->[Vertical ... Menu] --> USB computer connection), the option fails, and the last USB connection type is instead reverted. I tested this on a computer running Windows XP Professional with Service Pack 3.
I would think that it would be more convenient to always have the "USB computer connection" options always available regardless as to whether a USB connection is detected. Currently, a USB device must be detected before the options become available.
I do notice that there is an issue with the display of content while device is in the locked state. Sometimes, while trying to unlock device, the contents which should only be available after the device is unlocked is displayed for a short duration before it is replaced by the unlock pattern (I use a 6 x 6 grid pattern unlock) screen. I have not yet figured out the steps to reproduce the problem.
EDIT: Another issue: When attempting to unmount SD card via "Unmount SD card" option using the UI in Settings --> Storage, the Carbon ROM boot animation is shown and the operating system seems to reload. I use a 64GB microSDXC card formatted to the exFAT filesystem.
After doing some research, it seems that the MTP specification does provide for preservation or sending of a time and date combination. The actual sending of the that time and date combination appears to be optional. My guess is that the intention was to leave the time and date optional for those times the time and date is not available.Has MTP ever preserved the file time? Is it supposed to? I don't know... but I am not going to change that.
I am PMing you those logs.I will need logs for the sdcard issue. I can not reproduce..[emoji106]
Thanks. I shall soon use/test it.
Is the resized partiion ever restored to original size? If full device encryption is performed many times, would the data partition consequently be reduced more than 16k from the original size? For example, If the device encryption is performed 100 times, would the resized amount be 1600k?The data partition is automatically resized. Very small resize only 16k.
One thing that concerns me after reading the changelog for CARBON-5.1.1-METICULUS-20160728-0825-codinalte update-2 is:
Is the CARBON-5.1.1-METICULUS-20160728-0825-codinalte update-2 build the first build to perform the partition resizing when device encryption is attempted?
At what point does the data partition resize occur? (For example, during ROM first boot, after using the Encrypt phone option in the Storage category from Settings, etc.)
As an aside: Are the encryption strategies/algorithms used by Andorid AOSP and Samsung's implementation different with regards to partition size requirements?
I also notice that attempting to remount the microSD card, results in what appears to be an incomplete mount. Some Apps show an SD Car, others do not; the true SD card data remains unavailable. I have attached screenshots that I used to illustrate this using my 64GB exFAT-formatted microSDXC card. Do take note that after remounting the SD card, the size is reported as zero. The system may or may not bring-up the Carbon ROM animation afterwards.
Thanks. I am now on Update 2.I reviewed your logs and I think that update 2 will resolve your issues with your sdcard. I reverted an old KitKat hack regarding fuse mounting of external disks. Let me know if this issue persists beyond update 2.![]()
This is typical of UMS. That is why i only configured the external sdcard to work with UMS. Our internal sdcard is emulated, so I did not think that detaching would be possible..Thanks. I am now on Update 2.
EDIT: I do notice the the external SD Card is available to the USB connected host device, but becomes unavailable to the user on the mobile device
The only significant issues I am having at the moment are:If there are no other significant issues, I'm going to end development of this ROM and prepare to try to bring up MM. As soon as I have (/If I ever get ) a booting build, I will most likely post it in a new thread. It will probably have LOTS of stuff wrong with it, so it won't be a daily driver....
Absolutlely nothing... Those libs work exactly as the current ones do. But it will give us DEV's a chance to update and change the code as neededhey @Meticulus what will change with that new libs that you add to device tree ?
Power menu is available as a tile... [emoji6]The only significant issues I am having at the moment are:
In Settings --> CarbonROM Fibers --> Notification drawer --> Notification drawer -->, the "Power menu in expanded status bar" option's "Screen off - Power menu" and "Power menu - Screen off" do not behave as expected. Irrespective as to how long a press occurs on the Notification drawer status bar power button, the tap action is performed; the secondary actions (pressing and holding) do not work.
(I really do very much like having a software power button available)
