Root [Rom][5-17-12]Broken Out Connect 1.0 w/ Blitzkrieg Kernel
mtmichaelson
Hello all! Here it is Broken Out Rom for the LG Connect!!! It has been fully cleaned out to decrease size and to increase speed. It will continue to be a work in progress! I am working on this blind as I do not have the device. If you have a problem, I have no way to recreate it, so the more info you can get me, the better the chance I can fix it. If it's visual, please supply a screenshot, if an app problem, I will need a logcat. I hope you all enjoy!!!
What is this?
This is a very lightweight rom built both for speed and stability. This rom is based off of the latest LG version of Gingerbread, ZVA. It is fully deodexed, and debloated. Almost all of LG has been replaced and as time goes by, I hope to remove the rest.. A few items have been replaced with AOSP versions to increase speed and decrease size. Also included is the appwidgetpicker to clean that up.
Changelog
v. 1.0 Initial Release
Rom:
Based Off of ZVA Gingerbread
Deodexed
Zipaligned
Heavily Debloated
Sony Xperia S Theme
Custom Boot Animation
AOSP Lockscreen
Accurate Battery Mod
Center Clock Mod
Cleaned Up Status Bar
Cleaned Up Notification Pull Down
Changed Low Battery Pop Up to 1%
CRT Screen Shut Off
Added ICS Style Settings Menu
Build.prop Tweaks
Init.d Tweaks Including Scripts for Setting Governor and CPU Frequencies
Loopy Smoothness Tweak
Added Sony Bravia Engine
Added Xloud Driver
Made My Own Host File From Several Sources to Block Ads
Blocked All CIQ Logs From MPCS and Google (Requires Reboot After Install)
Added Google Voice
Added Terminal Emulator
Updated All System Apps Including Google Play
Kernel:
v. 1.0
OC Kernel
Overclock CPU to 1.8ghz
First Boot is Set at 1.5ghz
Undervolted
Added Smartass2, Interactive, and Lagfree Governors
Added BFQ and VR I/O Schedulers
Added SLQB Allocator
Changed From JHash2 to JHash3
Added ZRAM Swap (To Turn on Use Terminal Emulator Type "su" to Gain Root Access, Then Type "zram enable" )
Added CleanCache
Added Frontswap
Added zcache
Added xz Decompressor
Included tun.ko
Upped Charge Speed
Other Memory and Performance Edits
Lowered WiFi Voltages
I/O Tweaks
Audio Tweaks
Many Other Speed and Battery Tweaks
Too Many Tweaks to List (Check my Github For More Details!!!)
Screenshots
How do I install this?
1.) Download the .zip & make sure 4g is enabled.
2.) Place zip in external sdcard
3.) Back up
4.) WIPE DATA!!!
5.) Go to install zip from sdcard
6.) Select BrokenOutConnect1.0.zip
7.) Do not wipe data after flashing!!!
8.) Reboot!
9.) To Block CIQ Logs Requires Reboot After Initial Boot
Technical Info
This rom includes edits to several jar files, xml's and build.prop edits. As time goes more will be done.
Special Thanks!!!
xXxPachaxXx for Sony Bravia and Xloud
Shabby and PlayfulGod for porting over CWM
A HUGE thanks to cesarweezer for testing and being my eyes on this
Donations
For those that enjoy the work that I have done and would like to support my efforts financially through the donate to me button, any amount is appreciated, but all that I ask is that if you like my work, please hit the thanks button!!!
Awesome! Thanks again for the hardwork MT! ;) Test it out tonight! Any issues, i'll get back to ya!
Brilliant, installing now. What's this about Carrier IQ? I don't think it was in the original OS, was it? Just install, boot, reboot and it won't be able to log?
Antutu 6263 score! Ran it at 1500 performance
Don't freak out about boot animation because it takes a sec.
Very legit rom, download it asap
No LG hidden menu? Was checking out broswer proxy setting on LG optimizer and couldn't access it because it was taken out :p
pics
All I have to say is holy f00000 s000, finally thanks a billion mt been checking the forums everyday. Cant wait to try it out thanks a lot bro.
nice work man :)
2 things tho, it was playfulgod and me that did cwm
i noticed you keep mentioning CIQ, k0nane and i have yet to find any traces of ciq on metropcs, mind letting us know what you found etc?
nice work man :)
Sounds good I'll fix the credits.
As for the ciq, I have not found anything directly with ciq, but have removed any logging. I wrote the script right when ciq first came out and have just incorporated the same script into all of my roms.
Excellent! Fyi in case you weren't aware, the notification bar widgets lack the theming in landscape and when in portrait if you use silent without vibrate. Outside of that i'm loving this so far
Everything from the 3rd step down is done in CWM . Just a headsup for the people that might no be so familiar Custom Roms.
Thank you! I know about the landscape mode but didn't about the silent. If you can get me a screenshot of it that way I know the exact icon that would be great!
