Download Kangerade V4.0.7:
*all the following are full roms*
*see features below*
*installation instructions are below*
*view changelog here*
-Blueberry Flavored Froyo (Blue Theme) [mirror]
-Daiquri Ice Flavored Froyo (Cyan Theme) [mirror]
-Key Lime Pie Flavored Froyo (Green Theme) [mirror]
-Pink Lemonade Flavored Froyo (Pink-Life Theme) [mirror]
-Strawberry Flavored Froyo (Red Theme) [mirror]
-Plain Froyo (Stock Theme) [mirror]
-Froyo with Nex-Theme *credit to manup456* [mirror]
-Froyo with Nex-TANG by manup456 [mirror]
*feel free to post mirrors on this thread only*
Download Additional Goodies Here
*goodies have been updated*
*install as you would a rom*
*use custom scripts to apply*
Screen Shots:
Blue Theme:
Cyan Theme:
Green Theme:
Pink-Life Theme:
Red Theme:
Features:
-Built from source using FRF84B proprietary files and gapps
-Fully zipaligned & deodexed
-Complete music app overhaul by Eliot Stocker (from source & no FC)
-Added Kangerade scripts v0.4.2 by canvs2321 **donate to Canvs2321**
-10% battery increments for all themes (except nex-tang)
-DeskClock style tweaks from Nathan Zachary
-270 degree rotation and increased speed to Launcher2
-NexusMod like custom LiveWallpapers for kangerade (from Chris Soyars sexied up lwp)
-29 custom wallpapers
-Apps to sdcard scripts a2sdon, a2sdoff, a2sdauto
-Transperany for statusbar
-Reduced ring delay
-ChromeToPhone App
-Spare Parts App (for nice tweaking)
-Busybox v1.16.1 symlinked properly (ie. You don't have to type busybox w/ each command)
-Removed ads by default
-Disabled OTA updates
-Decreased call delay
-Increased wifi scan time to save battery life
-Added Pandora Radio
-Adobe Flash Player support
-Custom scripts
Custom Scripts:
*to view what each script does see this.. or use the scripts script*
To see what all those live wallpapers look like check this out
Kangerade Scripts app (by Canvs2321):
Other scripts:
a2sdauto - System will choose where to install apps
a2sdoff - All apps will be installed internally
a2sdon - All apps will be installed to your sdcard
mountsys - mounts system as read/write
unmountsys - mounts system as read only
scripts - lists all the scripts
backupapps - back up your applications stored in data/app and data/app private to your sdcard
restorebackup - restores your backup make from the backupapps script
blockads - blocks ads from apps
showads - shows ads from apps
soundoff - turns off camera shutter sound
soundon - restores camera shutter sound
godmode - gives permissions to system folders so any file manager app may access root
swtchba - switches your boot animation (must be named bootanimation.zip on the root of your sdcard)
switchlwp - swithces your live wallpaper (must be named LiveWallpapers.zip on the root of your sdcard)
rb - reboots your phone
rr - reboots into recovery
flashclockwork - flashes clockwork recovery
flashspr - flashes sprecovery
mountusb - mounts USB
unmountusb - unmounts USB
Clockwork Installation Instructions:
-Update & backup any files you wish to restore, this will wipe /data
-Place the ROM on the root of your sdcard
-Reboot into recovery mode (hold the power and "x" button at the same time)
-Install ZIP from sdcard
-Choose ZIP from sdcard
-Reboot and Enjoy!
SPRecovy Installation Instructions:
-Rename the rom to update.zip
-Install
-Allow update.zip Installation
-Install /sdcard/update.zip (depreciated)
-Reboot and Enjoy!
Donate to JRummy:
HUGE thanks to: {N8}, Xeudoxus, , INSANENEIVIESIS, jdlfg, Koush, Team Chaos, manup456, cyanogen, chevyno1, AdamZ, P3Droid, cvpcs, sniffle, slayher and other people I know I'm missing.
Even More Extras:
Install as you would any app:
Adobe Flash Player: HERE
ADWLuancher (from source w/ extra wallpapers): HERE
Kangerade Custom Sigs and QR Codes:
*Install roms w/ qr codes via rom manager
Blue Theme:
PHP:
http://i48.tinypic.com/jztctf.jpg
PHP:
http://i45.tinypic.com/zvvnv9.jpg
PHP:
http://i47.tinypic.com/rrt3wg.jpg
PHP:
http://i48.tinypic.com/2mqureu.jpg
PHP:
http://i46.tinypic.com/313r3pu.jpg
PHP:
http://i48.tinypic.com/2ueptw6.jpg
PHP:
http://i47.tinypic.com/5361wm.jpg
PHP:
http://i49.tinypic.com/3343fkm.jpg
PHP:
http://i47.tinypic.com/fmjrj7.jpg
PHP:
http://i48.tinypic.com/2d9e2cm.jpg
*apply as an update.zip*
Download Extras for Blue Theme:
2.0.1 Launcher
Launcher PRO *need to update*
Download Extras for Cyan Theme:
Themed Launchers:
2.0.1 Launcher
Download Extras for Green Theme:
Themed Launchers:
2.0.1 Launcher
Download Extras for Red Theme:
Themed Launchers:
2.0.1 Launcher
Download Extras for Pink-Life Theme:
Themed Launchers:
2.0.1 Launcher
Home++
Change your clock and notification colors:
*Rename to update.zip and apply in recovery.
*First boot up will take awhile... be patient!
Coming soon
