Root [ROM][Alpha][4.0.4]Codename Android 2.0.0
rukin5197
PRESENTS
[font=Roboto, helvetica, arial, sans-serif]
[/font]
Codename Android is a fully open source rom that focuses on speed, usability, and getting every feature that we can get CRAMMED in there :_con: .
Our mission is to spread the Open Source Android love to as many people as possible, and get as many people involved as possible. Along with the rom there will be tutorials to get more people involved and learning how to build android step by step.
SCREENSHOTS (From a different device)
[font=Roboto, helvetica, arial, sans-serif]---------[/font]
FEATURE LIST
Customizable Power Menu (reboot, profiles, screenshot, airplane mode, torch, navigation bar toggle, and silent toggle)
Statusbar Power Widget: (long press statusbar settings button to enable/disable - toggle Sleep, Media Buttons, Airplane Mode, Bluetooth, Brightness, GPS, LED Flashlight, LTE, Mobiledata, Sound, Sync WiFi, WiFi AP, and WiMAX)
Customizable Battery Status (icon style and miui style battery bar)
Customizable Clock (clock style, am/pm style, clock color, and toggleable alarm clock icon)
Customizable Signal Status (style)
Customizable number of lockscreen targets
Customizable lockscreen layout
Customizable lockscreen text color
Configurable lockscreen wallpaper
Ability to unlock with menu
Quick pin unlock (unlock with pin/password without pressing ok)
Lockscreen before unlock (extra lockscreen before the PIN face lock, pattern, or password lockscreen)
Ability to enable rotation on the lockscreen
Sound toggle for camera (replaces the camera unlock target with one for toggling the sound settings)
Volume wake (tap either the up ordown volume key to wake your phone from sleep)
Volume music controls (long press volume buttons to skip tracks)
Wait to lock screen (use androids timeout setting after you manually turn the screen off)
Customizable Navigation Bar:
- menu button visibility and location
- number of navigation buttons
- order of navigation buttons
- color of navigation buttons
- navigation bar size
- button glow animation speed
- navigation button transparency
Custom Automatic Backlight Settings
Customizable Rotation Modes
Customizable Screen On/Off Animations
Customizable LED Pulse (Duration and Color)
USB Fast Charge Mode
Ability to enable extra volume options (pressing the volume opens sliders for ringtone, alarms, notifications, and media sounds)
Customizable Custom Carrier Label
Customizable Statusbar Transparency
Optional WebOs Style Recents List
Performance Settings:
- Start-Up Tweaks (configurable tweaks that run at boot - zipalign apps, enable sd card boost, fix permission, clear cache, enable sysctl, enable scheduled tasks)
- Processor Speed (change cpu governor and clock speed)
- Processor Voltage (changes cpu voltage of each frequency)
- Memory Management (customize the usage of memory to alter system performance0
- Disable boot animation (skip the boot animation for a faster boot)
Custom Profiles (assign different profiles to change the behavior of your phone to your liking)
Quiet Hours (the ability to set when and how notification sounds, haptic feedback, vibration and notification light will function between a certain times e.g. "Quiet Hours")
Custom Launcher: (Originally built off of Trebuchet)
- customizable number of homescreens
- customizable default homescreen
- removable search bar
- ability to resize any widget
- ability to hide icon lablels
- configurable transition effects
- ability to enable rotation
Ability to unlink volumes and mute states
Ability to turn off the USB debugging notification
ADB over Network (enable TCP/IP debugging over Network interfaces (WiFi, Usb networks) )
Configurable root access (disabled, apps only, ADB only, or Apps and ADB)
Optional Long Press Back to Kill Apps
Advanced Testing:
- Configurable Build.Prop
- Spare Parts Settings
- Development Settings
- Testing Settings
LATEST CHANGELOG
### 2.0.0
* update to 4.0.4
Check full changelog at link below
ROM
Codename-Android-(MOD)-2.0.0-RC-Triumph-UNOFFICIAL.zip
MD5 = [font=Roboto, helvetica, arial, sans-serif]e38267e9f7c53636632fffef2f930fa4[/font]
GApps HERE
Filename gapps-ics-20120429-signed.zip
MD5sum 7c524e1e078164f681e0aa6753180b2c
BUGS
--Camera isn't working
--I've occured some random freezes that lead to a reboot, but that could just be me.
Some of the stuff in Advanced Testing in Settings can bork your build/cause a brick. So unless you know what you're doing, stay out of there for now.
--HDMI is not working. I didn't expect people to believe that it was, but.. lol.
--You tell me.
FLASHING INSTRUCTIONS
[font=Roboto, helvetica, arial, sans-serif][font=Roboto, Helvetica, arial, sans-serif]1. Make a backup[/font][/font]
[font=Roboto, helvetica, arial, sans-serif][font=Roboto, Helvetica, arial, sans-serif]2. Wipe data/factory reset in recovery[/font][/font]
[font=Roboto, helvetica, arial, sans-serif][font=Roboto, Helvetica, arial, sans-serif]3. Flash Codename-Android-(MOD)-2.0.0-RC-Triumph-UNOFFICIAL.zip [/font][/font]
[font=Roboto, helvetica, arial, sans-serif][font=Roboto, Helvetica, arial, sans-serif]4. Flash GApps[/font][/font]
[font=Roboto, helvetica, arial, sans-serif][font=Roboto, Helvetica, arial, sans-serif]5. Reboot[/font][/font]
[font=Roboto, helvetica, arial, sans-serif][font=Roboto, Helvetica, arial, sans-serif]6. Sign in[/font][/font]
[font=Roboto, helvetica, arial, sans-serif][font=Roboto, Helvetica, arial, sans-serif]7. Wait for the phone to restore all your apps[/font][/font]
[font=Roboto, helvetica, arial, sans-serif][font=Roboto, Helvetica, arial, sans-serif]8. Reboot[/font][/font]
CREDIT/THANKS
[font=Roboto, helvetica, arial, sans-serif]---------[/font]​
EVERYBODY IN THE ANDROID ATMOSPHERE!!! :_con:
All other open sourcers that made a contribution to the project:
Specifically: Google, AOKP, CM, Team Gummy, RootzBoat
And of course, the main man for getting me through my errors, Mantera
DONATIONS
Please tell me if I forgot your name/if you want a donation link.
Donate to Gannon5197
Donate to Mantera
Donate to Whyzor
Will be interested to see how you guys compare this to cm9 as far as stability. Also curious to see if it still has the Netflix not playing issue.
So if we stay away from advanced settings, we will be ok? The whole bricking my phone thing worries me.
I can't seem to get wifi to come on.
Edit: Nevermind - reboot fixed it. But the play store is not redownloading apps and is trying to charge for apps I already own again.... Going to attempt reflashing again.
Edit 2: Reflashed. Rebooted as soon as it finished booting up. Then after logging it all in all seems to be working ok.
Edit 3: Got it up and running and reset up as I like it. So far the customization is pretty cool (centered clock, choosing the look of the battery, custom carrier name etc.). It does seems slightly faster than CM9 to the touch (I seem to be doing less retouching to open things) and also a little faster loading. The camera obviously doesn't work as stated before. The bug with Netflix and google videos also seems to still be there. Will post more when have played with it more. So far: pretty happy with it. Have the same look as CM9 (which makes since with both being ICS) but seems a little quicker and more room to customize.
Edit 4: GPS found me inside the building I work in in around 30 seconds (within 20 feet at least). Also not a huge gamer but Angry birds seems to work fine. Bluetooth and wifi also seem to be able to play in the same sandbox together on here as well.
ok im runnng this rom and currently im loving it as much as cm9. i got to say cm9 has competition. im loving this rom. it has much more and i mean MUCH MORE features then cm9. more customization (which i love :) ) battery life so far is the same. no lag ( running v6 supercharger :D) and smooth. ril is working. data is working. its good so far. hoping to see this develope into something greater :D
i believe theres a bug with email? i cannot open a mail with an attachment. it seems to force close email.
EDIT: nvm it works...but for certain emails it doesnt...idk y o.o
