It'll be nice to see camera in ICS finally and then I can activate Google Authenticator easier then too
Upvote
0
Finally done. Grab it while it's still steaming
Stopped by on a whim to check if ICS is possible on Android yet, and I was pleasantly surprised when I found that it is. After trying all the ROMs that support it, I settled on this as being clearly the best. ICS is awesome; so much nicer looking than Froyo, and for some reason the Facebook app doesn't stall out constantly now. I wonder if I'll find that more of my apps run better under ICS. The touch screen definitely works better.
Two questions though:
1) Any thoughts on when the camera will be available? Facial recognition unlocking was probably the most exciting feature of 4.0, for me, so I'm stoked to try it out.
2) When I flash an update of the ROM, will all my settings be lost? I'm a bit of a customization nut, so I don't want to put too much time in if I'm going to have to start all over.
Great job on this ROM! Thanks again for all your hard work.
Is it just me I thought there is suppose to be a data toggle in this update. I dont see it it even shows a preview image of data toggle
+1!!! Exactly wat i thought!!! but it wasnt which made me go back to cm9. im not saying that this is a bad rom. its just for convenience. also i kinda slimmed down both cm9 and aokp b38 n both r running great n smooth. only 80 Mb each xD. so much bloatware.
GPS Should've been fixed.. not sure.
I must have an amazing phone, as I'm not occurring the tiles anymore. Guess I'll have to look more into it. Sorry guys.
Like I said I've seen the tile glitch once and it fixed itself. As for GPS its enabled in settings but apps can't find my location. So I used a trusty GPS tool I've used before to see if GPS was connecting and it wasn't showing as being on regardless of settings saying it was
My final build on here. Sorry guys. No updates though.
