Root [ROM][ALPHA][5.1.1] Dirty Unicorns 4/29/2015
Anyone on newest nameless rebooting when you plug the charger in?
I'm on it don't have that problem u need to get a log posted so some one who knows how to read them can fix it did u do system restore and format data before flashing nameless?
Was afraid you would say that... Just switched phones. Did a clean install so I think it's a hardware issue. Wasn't able to get catlog as it didn't save but pulled kmsg. Not sure if anything is in there though.
*Yes*
@KellyDraves
In Starkravings number 5
You need to wipe system as well whenever upgrading OSs.
... So
In custom recovery
*mounts and storage
/format system
/format data
/format cache
*advanced
/wipe dalvik
Also I always do:
*Wipe data/factory reset
*Wipe cache partition
^^all in recovery
-follow the rest of what Starkraving has posted-
PS: all (*) are indicative of options found on the first screen of your custom recovery.
Okay, thanks. The version of TWRP was weird I guess because it did not take me to the usual recovery screen. successfully flashed the rom though. Except now, I am stuck on the reboot screen. All I see and have been seeing for the last 5 mins or so is a red unicorn with a spinning blue and white lollipop behind it. I am guessing something is wrong. What now?
Never mind. Literally just started to do something as soon as I hit "post". Well so far so good. I like what I see! Can hardly believe it is still my same phone haha. Thanks guys for your hard work and thank you for those of you who helped me along the way!
@KellyDraves
First boot can take a while sometimes especially coming from KK to Lollipop, takes ART a long time to compile on first boot. If after 10 minutes or so I'd reboot (reboot finished off the initial boot on the Moto G when it would "hang")
Keep us posted. [emoji106]
Okay, I have a couple questions after playing around on this for awhile. One, is there a way to move apps to my SD card? I have no more room on my device and it will not let me finish downloading apps or move previously installed apps onto my SD card. Second, when I get notifications, a little bar will appear at the top of my screen for a few moments as an alert. I can't seem to find where to turn this off, or is it possible at all? Also, I tried to download a camera since it did not come with one but it does not work either. Any suggestions? I know it was mentioned that the camera was iffy but I thought downloading a camera app would work.
Yes u can there are APS out there but if u go to settings then to apps u can move some that way
I have an app that moves apps to external SD but even this gives me a message of "No need to move apps to SD card. SD card and OS share the same disk". I also go to the app info and click the button to move to SD card, but it says not enough room which I know is false because I have over 21 gigs on my SD card. Not sure what I should do next.
I love this rom but I think I am just going to downgrade to 4.4.4 for now until the official fixed 5.1.1 comes out. I just have to have the ability to move apps to my SD card to free up internal storage, and a camera. Can't go without those. Can't wait till the official fixed version!!
Fx camera zoom works great it will alow u to use the Boton on the phone to I do some looking to find the app to ext sd
Fx camera zoom works great it will slow u to use the Bolton on the phone to I do some looking to find the app to ext sd
I use the send to sd app. It has a picture of a little android holding an SD card. It worked great before I installed the rom. Let me know if you find anything? And I'll look into that camera. Thanks!
Go to settings then to APS up in top right. Of screen u see three dots click on then then u can change were the apps in stall its on the XDA site there is a lot of info there check it. Out
If any body wants better frame rates put this on your build prop debug.egl.swap interval=-60 u will see a divergence thanks to stark for this find really made a difference
