Root [ROM][ALPHA][5.1.1] Dirty Unicorns 4/29/2015
Starkraving, post: 6964916, member: 1468422"]Potential native camera help??? [emoji15]
Yes, you're spot on! Thats exactly why I wanted to bring this to the attention of others. I was wondering if it contained the info needed to fix the camera (like a merge sources kind of deal), however, I am by no means a dev, at best I'm just an amateur with a desire to tinker and learn, so I'm not sure if that info is in there, nor do I have Ubuntu set up, so I can't really dig around in that either. I hope the link is helpful. I don't know enough to know if it is, it looked important to me though, so I thought I'd share and ask about it. It also requires you to agree to zte's terms of use/disclaimer before downloading, which is what set me off to thinking it might have some blobs in there that are needed for the camera.
ZTE is horrible about source releases... Almost non compliant with open source. GPL, GNU etc...bastards lol.
The individual who provided phen basket can u plz relink it thanks
You have knowledge of the site where the links are located...
Basketbuild.com is all I have to say.
Shall we agree to keep public direct ROM linking on a per thread basis to be provided by the Dev when he has the time. If for anything to keep thread clutter down and respect values high. Downloading from the host has been given complete permissive access to, but if someone asks, can we point to the site home directly or otherwise send a PM?
Shall we agree to keep public direct ROM linking on a per thread basis to be provided by the Dev when he has the time. If for anything to keep thread clutter down and respect values high. Downloading from the host has been given complete permissive access to, but if someone asks, can we point to the site directly or otherwise send a PM?
That sounds good to me
I will say that I was unaware of the link that was provided a few days back and once I checked it out, I DLed Gummy and Bliss because I had not tried either. I had heard a few mentions of Gummy so I saw those and they caught my eye. I'm actually using bliss right now...I like it quite a bit thus far and really liked Gummy too.
Edit. I also liked DU 5.1 but decided to flip back to KK. I'll make the Lolli jump again once recents are implemented.
Edit. I also liked DU 5.1 but decided to flip back to KK. I'll make the Lolli jump again once recents are implemented.[/QUOTE]
The ROM in question is still up on PhenomX4 dropbox . Just go to the ROM download page and on the left side of the download button you will see his name by developer . Click on it and it will take you to another page . Look for the link that says n800 . in there you will find an updated version of DU with the recent apps and fixed browser .
The ROM in question is still up on PhenomX4 dropbox . Just go to the ROM download page and on the left side of the download button you will see his name by developer . Click on it and it will take you to another page . Look for the link that says n800 . in there you will find an updated version of DU with the recent apps and fixed browser .[/QUOTE]
Thanks for the info phen is till trying to fix app crashes that pertain web view once that is fixed ROMs will pump out
He might not know how to get a log for that... @syrkles First things first, in development settings enable the built in terminal app if it isn't already, (you probably need a reboot after enabling it), then as soon as you get a random reboot, open terminal and type "su" enter, you'll get a root access prompt, allow it, then type the following into the terminal, "cat /proc/last_kmsg > /sdcard1/last_kmsg.txt" it should dump a text file of the reboot issue onto your sdcard. Grab that and get it to phenomx4. Remember to leave out the quotes when entering the commands. If you get an error trying to output the log, try sending out to sdcard0, which should be internal storage.
