[rom][alpha]AOKP 41
Connorh333
DISCLAIMER: This is a CUSTOM ROM! Use at YOUR OWN RISK!!! By using this ROM, you understand that that neither I nor any other developer is liable for any or all consequences of using this ROM.
AOKP rom based on android 4.1.2.
a1:
https://www.dropbox.com/s/oi9wkakl3lfikf6/Lucid_AOKP_A2.zip
Camera and gps dont work.
It has the same problems as the A1 version of Cyanogenmod 10 but it flashes and boots.
A2:
https://www.dropbox.com/s/f2r257qp2imw84t/AOKP LG LUCID.zip
A2 is untested and might not flash. If someone could try it that would be awesome. If it does flash it should boot and everything should work.
Credits to Stcarlso for the kernel and source!
A2 Doesn't flash, I got set_perm: some changes failed and Error in AOKP LG LUCID.zip (status 7) when trying to flash over Cyanogenmod 10 B2. Will wipe everything when I have a backup and try it then.
Edit: I did a clean wipe and still got the same thing. Seems to be an error in the permissions or something. I'm not good at this kind of stuff, but I am willing to test!
for symlink failed, try flashing stock. I'm not willing to do that cause I need my phone, but if somebody wants to do that, I think that might work.
nope... did KDZ back to stock GB, rooted, installed cwm recovery, no flash... :( i will test and try to get adb to work to get this rom going.
i am completely stuck. to make any progress at all i would need someone to take a logcat while flashing this.
Edit: My new lucid is coming friday!
edit 2: can someone try flashing the cwm touch and then try flashing a2. If it still doesnt work please try to pull a log while flashing
I'll try tomorrow
I got CWMT installed and when I tried to install your ROM, I get a status 7 error. I'm not sure what I'm missing, but I can't pull a logcat from CWMT. I read somewhere that logcat isn't a feature with this recover. When I pull up adb devices, it shows a device as offline as well. I did use the show log option in advanced and can give you that if you want.
The log from advanced options is fine as well. Thank you
I think it's this line:
[HIGH]symlink("mksh", "/system/bin/sh");[/HIGH]
There's a /system/xbin/sh but no /system/bin/sh if I read the script correctly. Also, the zip's folder is named "System" but probably should be "system" (it may be case sensitive)
