Connorh333
before installing can you open up the rom's build.prop and change this line:
persist.adb.notify=0
To this:
persist.adb.notify=1
(it is on line 133 if you use notepad++)
Then wipe data, then try to pull a log.
Thanks in advance
To this:
Thanks in advance
(sorta)
) I think either b3 or cm10.1 are coming out soon. Once they do I will attempt at making this rom work! If you know how, after this rom bootloops for a couple of minutes can you pull a logcat through adb? Especially if you have something running linux.
