Root [ROM][ALPHA] Quattrimus ICS
Flashed Cm9 and made a backup. Badass rom, great job. I can't wait until I get off work so I can check it out fully
It is still in alpha, although some of the things in the OP have been fixed by bloodawns kernel such as vibration, and cpu settings not sticking. tdm will be implementing these in his next release i believe.
Once he implements bloodawns fixes and the camera, I'm pretty sure tdm will move this to beta stage. Things have come really far since our first rom by monster.
i flashed the gapps and it still doesn't work :,(
Go back into recovery, clear cache/dalvik cache, flash gapps, when it's done flashing go back into advanced and fix permissions, then reboot. You should have already gone through the setup wizard after you flashed CM9 before doing any of this.
i just flashed the alpha2 rom and it says my carrier is spint on the lockscreen? does this mean my marquee is on sprints network is there a quick fix for that?
Technically, you're always on the Sprint network. ;)
If you are using a Sprint baseband, your phone will be detected as an LS855. Override the model per the first post to fix it.
thanks:) but now i have another problem sorry to be bothering you so much i saw in the development thread i dont remember who but the person said in the cpu controls he/she had it ondemandX and his/her battery life was amazing so i changed mine but now i seem to be stuck in a bootloop can you help me? :s sorry to post the same problem in both threads btw
Got Bloodawn's changes in and it looks like the vibrator and governor stuff is fixed.
Also made the G-key to bring up the camera.
Unfortunately, I am still fighting with the 3G routing. I'll try to get that fixed shortly.
i have an lg marquee btw
Awesome. I'll be giving it a shot when you post it. Gracias, senor.
Thank you all for your help :)...for some reason it only works when i flash it over my old CtMod back up and not my regular Zv4 not sure why
alpha3 is up.
Changes:
* Bloodawn's kernel and init changes for vibrator and cpu.
* Fixed G key.
Note this is built from sources at github.com/thebigq. I don't have all the stuff checked in yet but I'm working on it.
Also I'm hard at work on bringing up AOKP. Should have that soon.
in a1 and 2 iv noticed that the phone ringer doesn't typically ring, it doesn't make the typical audible sound when turning up or down the volume. will test a3 and report back.
awesome advancements since iv used it last. got the epic 4g touch then managed to break the screen back to the marquee for now.
  • Like
Reactions: tdm
Works here on a3.
hey tdm amazing work and in the first post you said how to fix the carrier problem but im a noob and even though you explained it i still dont understand how can you explain differently?
  • Like
Reactions: tdm
I don't really know how to make it more clear. Perhaps someone else can walk you through your issue.
