I have a question... Since data and sms work doesn't that mean that mms should work? or is it a totally different setup?
I just tested MMS on my build from this morning (Mantera's repo) and can confirm that MMS does NOT work yet.
Oh, shit! My work shift starts in exactly 22 minutes.
I think I'ma be late for the first time in my life. I won't leave my house until my phone has ICS installed.
Does GPS Work?? ??????????????????
If you devs need some advice about MMS, I know these two guys might be able to give advice:
Android Forums - View Profile: JerryScript
Android Forums - View Profile: simonsimons34
They make ROMs for the OV and Wildfire S and have commented about the MMS issues from Virgin Mobile before. You may not need it, but if you run into trouble and can't figure it out (or see if you can save yourselves some headaches) I would check with them.
OK so I'm making a list of crucial things that need to work in cm9....
- GPS
- MMS
- Wifi hotspot
And if it's even possible...
- HDMI
I'm looking at you programmers
Thanks so much for a working rom the very least
Dude.. you may be joking around, but you really need to relax on this.. these guys have been busting their butts to get this out.. so be patient.
